Pocket GPS World :: View topic - Garmin and traffic
Garmin and traffic
highlander317
PostPosted: Sat Oct 02, 2021 1:36 pm    Post subject: Garmin and traffic Reply with quote
Recently changed jobs and am now back on the road again, sadly I didn't realise that Garmin had ended their hd traffic service.
I feel quite hard by, probably along with many others paying for something marked as "Lifetime" yet expired already.
After a bit of digging about various sites, I eventually found that it indeed ended in June 2021.
Anyone having any luck using a smartphone connected to the sat nav or via FM rds signals? I've been using it for the last 3 weeks with no mention of traffic, despite being caught in many queues caused by the fuel scaremongered lemmings and roadworks, not a single mention on the sat nav of anything along my journey.
I'm using a Nuvi 2598 LMTD, the cable powers up ok, so I've hopefully ruled out a faulty cable.
Cheers for any advice or help
PostPosted: Sat Oct 02, 2021 2:12 pm    Post subject: Reply with quote
I'm finding the Smartlink traffic just as good as the old TA cable traffic.
I have used Smartlink in the past and it was terrible but it seems vastly improved. I reckon they've switched from viaMichelin to Inrix because the alerts are identical to what I was used to.
PostPosted: Sun Oct 03, 2021 6:56 am    Post subject: Reply with quote
Should work ok, mine does. Have you checked to see if it's paired properly with your device? When it is it should be obvious when you select the traffic app on your nuvi.
INTRANET
PostPosted: Sun Oct 03, 2021 7:21 am    Post subject: Reply with quote
I have Garmin Drive app connected with my Nav. And as far where I drive it shows traffic info.
marksfish
PostPosted: Tue Oct 05, 2021 7:21 pm    Post subject: Reply with quote
I'm still using the traffic cable on mine and getting alerts/ re- routes, some out of date (such as in Bristol this weekend, but then Waze wasn't 100%). I haven't updated mine to remove the service yet, so not sure if that is helping?
PostPosted: Wed Oct 06, 2021 4:33 am    Post subject: Reply with quote
That's odd.
The digital service that transmitted the traffic data has been turned off !
TPEG or whatever it was has no data. Maybe yours has defaulted to TMC RDS which is still working AFAIK.
marksfish
PostPosted: Wed Oct 06, 2021 7:06 am    Post subject: Reply with quote
I'm presuming it is TMC as I haven't changed any settings on the unit since digital was deactivated. I'll have a look at what it is using when I next fire it up.
PostPosted: Wed Oct 06, 2021 8:23 am    Post subject: Reply with quote
TMC only covers motorways and main A roads. It's very slow to update and as a result can lead to many inaccurate reports both emerging and cleared roads.
Honda have stopped supplying it on their Garmin built in systems as it's so poor.
cjay2412
PostPosted: Wed Oct 06, 2021 8:38 pm    Post subject: Reply with quote
to be fair inrix tmc which is the fallback option now digital isn't available has reasonable coverage with all motorways and a_roads covered including slip roads, 98000km of B-roads and 3200km of unclassified roads covered. bandwidth is a problem for the service. during rush hour, for example, low impact incidents i.e. roadworks with no delay won't be broadcast favouring higher impact incidents like congestion. updates are also slower, updated at a rate of <15mins continuous. the more incidents in an area the longer the update time. yes it does have its issues but it's not a bad service
PostPosted: Thu Oct 07, 2021 4:55 am    Post subject: Reply with quote
If you can I'd still recommend trying Smartlink as it's very good now.
cjay2412
PostPosted: Thu Oct 07, 2021 10:31 am    Post subject: Reply with quote
Yes, digital traffic is better than TMC. If you can use it. If not TMC is an ok backup
23.043 (17 Apr 25)
