Newsletter
Pocket GPS World :: View topic - Mercedes Comand Online ntg4.5 - Personal POI data support
Goto page Previous  1, 2, 3 ... 14, 15, 16
daxeno
PostPosted: Thu Jun 25, 2020 9:56 am    Post subject: Reply with quote
Hi everyone...
i have just bought a nav software for Mercedes Benz GLA 2019.
when i inserted the SD Card, it won't read the card and it says
"No Memory Card Containing Navigation Software installed"
any help to fix this would be much appreciated.
Thanks!
Nemesis1
PostPosted: Wed Aug 05, 2020 7:51 pm    Post subject: Reply with quote
Here we go again.....
Laughing
Just got my 2020 C300DE with command online yesterday.
Canít get anything to load. All trace of personal POI, or navigating to a poi from an SD card has been removed from the system.
PostPosted: Thu Aug 06, 2020 9:46 am    Post subject: Reply with quote
daxeno seemed to be talking about new Sat Nav software, not user POIs.
Clarification would help.
Nemesis1
PostPosted: Sun Aug 09, 2020 7:13 pm    Post subject: Reply with quote
So command online is HDD run, not SD card like the audio 20 version.
There is no option I can see anywhere in any menu that would indicate you can load personal POIís onto the system :-(
gbw
PostPosted: Mon Nov 02, 2020 10:15 pm    Post subject: Mercedes A class Reply with quote
You need the latest MBUX software (from late March 2000. Earlier versions did not give audible warning. You can use the Mercedes single file from here but it must be in a folder called PersonalPOI on a memory stick plugged into the front set of usb sockets. You can also music on this memory stick if you wish as long as it is another folder.
Set up the pio option in navigation.
You will get a graphic on the map and a beep - not awfully loud and only about 100yds before hand.
Have a look at the "AClass Club Forum" elsewhere for more information.
PostPosted: Tue Nov 03, 2020 1:39 pm    Post subject: Re: Mercedes A class Reply with quote
Are the instructions here still relevant: https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=583794#583794
Or is this a new system from the Comand?
Nemesis1
PostPosted: Tue Nov 03, 2020 8:25 pm    Post subject: Re: Mercedes A class Reply with quote
Unfortunately no good for Command online (NTG 5.2) mate
And yes, MBUX is different again.
Still hoping some one finds a way to add to the new command, but nothing I can figure out or find so far. There is no option in any menu for Ďpersonal POIí.
The system does have POI baked in, and you can save locations, so just need to find a way into the software to input the locations.
PostPosted: Thu Nov 19, 2020 8:03 pm    Post subject: Reply with quote
Hi all,
Could someone knowledgeable about the Mercedes Comand system pop over to this thread and try help?
https://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=99644
Unfortunately without having access to every Mercedes and subsequent version and update it's impossible to be able to know the ins and outs of it...
Dabaws
PostPosted: Sat Dec 19, 2020 1:15 pm    Post subject: Re: Mercedes A class Reply with quote
I have a W177 Mercedes A Class and i want to get speed camera POI on my MBUX. How do I do this? Do i just download the files as normal? There are no instructions on this site for MBUX.
PostPosted: Sat Dec 19, 2020 2:32 pm    Post subject: Reply with quote
You have actually quoted instructions on how to do it. Have you even tried that?
Dabaws
PostPosted: Sat Dec 19, 2020 2:46 pm    Post subject: Reply with quote
The instructions are for Mercedes Command, not Mercedes MBUX. Iíve checked and canít find any mention of these POIs working on MBUX. I donít want to pay for a subscription that might not work.
PostPosted: Sat Dec 19, 2020 9:20 pm    Post subject: Reply with quote
Oh sorry. I was completely fooled into tying the first five words in the quote to the first sentence of your question. Silly me.
But in my defence, I have a lowly Honda, not a Merc.
The single file Merc download is in .gpx format, so not easy to see the underlying format.
PostPosted: Sun Dec 20, 2020 5:36 am    Post subject: Reply with quote
With the previous Merc format the GPX contents needed to be in full capitalised text.
I don't know if that restriction still exists. 50 mph for example needed to be converted to FIFTY MPH. I can't remember what else Nemesis1 found but it's all in his thread.
Satnav:
Page 16 of 16
19.094 (22 Sep 21)
