Newsletter
Pocket GPS World :: View topic - Transferring saved favourites to a in built car satnav
turkishbosher666
PostPosted: Fri Nov 13, 2020 5:56 pm    Post subject: Transferring saved favourites to a in built car satnav Reply with quote
Hello
Need help at preset I have a Garmin. 2599 with loads of saved favourites, how do I transfer these to my in built car satnav,Suzuki vitara infotainment system 2016,
Any help apprenticed.
PostPosted: Fri Nov 13, 2020 6:32 pm    Post subject: Reply with quote
If your built in satnav will accept .gpx files then your favourites can be found in current.gpx on your nuvi. If your built in satnav wont accept .gpx files then let us know what it will accept?
BigJohnD
PostPosted: Sat Nov 14, 2020 1:54 pm    Post subject: Reply with quote
The manual suggests POIs can be added in standard .CSV format.
PostPosted: Sat Nov 14, 2020 2:19 pm    Post subject: Reply with quote
POIs and favourites are different though, at least in Garmin speak. If it'll take .csv files then you could load your favourites into BaseCamp and export them as .csv files.
turkishbosher666
PostPosted: Tue Nov 17, 2020 3:46 pm    Post subject: Reply with quote
Thanks for all your replies converted the gpx files to CSV but still no joy
PostPosted: Wed Nov 18, 2020 9:28 am    Post subject: Reply with quote
Is this a physical manual or an online one we can look at?
BigJohnD
PostPosted: Wed Nov 18, 2020 1:25 pm    Post subject: Reply with quote
See here, Page 52: http://www.suzuki-slda.com/Lists/User%20Manuals/User%20manual%20SLDA%20Europe_EN.pdf
8.12.1 Data format
The file containing your own points of interest must comply with the WGS84 standard.
The required file format is “.csv”.
Each line of the file may describe one point of interest containing the following pieces of information:
ffLongitude
ffLatitude
ffName
ffAddress (optional)
ffTelephone number (optional)
A line of the file may look like this:
77.61,12.92,Park,Bangalore City,00917829
turkishbosher666
PostPosted: Wed Nov 18, 2020 3:20 pm    Post subject: Reply with quote
Downloaded a few poi's
A tried everything suggested no joy, driving me nuts now what am I doing wrong? example of one of the poi's that I've done.
"myPOI-Warnings_csv"2.362751.38143 Bath Monmouth At local
[/img]
PostPosted: Wed Nov 18, 2020 4:41 pm    Post subject: Reply with quote
[/img]
That doesn't look right..
It should be something like :
-2.71,51.81,Monmouth
But that depends on the Lon/Lat required. Some require a NSEW notation as well.
From what I can find it needs to follow the WGS84 standard
Satnav:
PostPosted: Wed Nov 18, 2020 7:12 pm    Post subject: Reply with quote
Assuming "myPOI-Warnings_csv" is the filename then it needs to be .csv at the end and not _csv. If there is no '.' shown then you will need to 'unhide' file extensions and make sure it is a .csv file.
'CSV' stands for Comma Separated Values - i.e. in the main file each field is marked by a comma. The contents of the file above does not have any commas. It should be:
Code:
2.3627,51.38143,Bath Monmouth At local
which would have the name as 'Bath Monmouth At local'
or
Code:
2.3627,51.38143,Bath Monmouth,At local
which would have the name as 'Bath Monmouth' and the address/details as 'At local'
Hope this helps
turkishbosher666
PostPosted: Fri Nov 20, 2020 11:08 am    Post subject: Reply with quote
Thanks for everyone's replies tried everything suggested but still not working, infotainment system doesn't recognise any files on usb drive,so going to use my Garmin for safety camera warnings not Ideal,as just wanted to use the 1 system for everything,but not happening ☹️☹️☹️
PostPosted: Fri Nov 20, 2020 12:27 pm    Post subject: Reply with quote
Even if you got the upload to work, many systems are not capable of producing the advance warning that cameras require.
If you can bluetooth your phone to the head unit consider using CamerAlert or SpeedTrap Alert, both of which produce PGPSW directional alerts.
Satnav:
PostPosted: Mon Nov 23, 2020 11:26 am    Post subject: Reply with quote
If you email me the file I can take a look and see if there's anything obvious: MaFt AT pocketgpsworld DOT com
20.013 (19 Jan 22)
