Pocket GPS World :: View topic - No alerts/incorrect alerts Garmin 276cx
berin
PostPosted: Tue Oct 27, 2020 8:10 pm    Post subject: No alerts/incorrect alerts Garmin 276cx Reply with quote
Something weird happening with my Garmin GPSmap 276CX.
I load the UK database with POI loader, express settings - but I'm not alerted to the cameras.
The camera database is in /garmin/poi as uk.gpi
On the device, the database is there under points/proximity. Proximity alarm is set to on.
If I look at an individual camera, on the device under points/extras, then for example E-GATSO11261 show alarm 0.3mi, alarm above 30mph.
Camera E-Mobile17500 shows alarm range 0.4mi, alarm above 40mph.
Any ideas?
PhilHornby
PostPosted: Wed Oct 28, 2020 3:27 am    Post subject: Re: No alerts/incorrect alerts Garmin 276cx Reply with quote
berin wrote:
Any ideas?
I'm not familiar with the 276CX, but if you built the .GPI file and it had associated audio in a format the 276CX doesn't support, it might do this - though defaulting to a 'bong' is more likely.
I take it that audio in general, does work on the device (my original Zumo 346 was mute from day 1)
(Does it have individual volume controls for different types of audio - a 'Mixer' setting?)
PostPosted: Wed Oct 28, 2020 4:59 am    Post subject: Reply with quote
Garmin POILoader requires the SOX file to produce spoken alerts using WAV files.
Read my 'spoon feed ' thread in the Garmin area.
Satnav:
berin
PostPosted: Wed Oct 28, 2020 10:01 am    Post subject: Re: No alerts/incorrect alerts Garmin 276cx Reply with quote
PhilHornby wrote:
berin wrote:
Any ideas?
I don't use the audio alerts (I use the device on a motorbike) but my other devices alert via the screen (either in a pop up or on a banner) but I'm not seeing any kind of alert, audio or visual.
PhilHornby
PostPosted: Wed Oct 28, 2020 3:47 pm    Post subject: Re: No alerts/incorrect alerts Garmin 276cx Reply with quote
If it's not generating any kind of alert...
perhaps try to create a much simpler .GPI file (just one point, in .CSV format)
Code:
Format: longitude,latitude,Name,Comment
e.g.
-1.772299,53.622208,TestPoint,TestAlert
and then use the 'GPS simulator' to simulate rides past the point you've chosen. I'm assuming the 276CX has that feature.
(Something's stirring in my memory, that you need at least 2 points in a .csv file for them to work - but even if true, it was many versions of POILoader ago and may not still apply)
PostPosted: Wed Oct 28, 2020 3:47 pm    Post subject: Reply with quote
From memory there's a setting to turn on alerts for POIs? Been a while since I've used a Garmin so can't be any more specific than that...
Also if Garmin decides you're too far under the speed alert then it simply won't show anything.
PhilHornby
PostPosted: Wed Oct 28, 2020 3:48 pm    Post subject: Reply with quote
He's a biker Laughing
berin
PostPosted: Wed Oct 28, 2020 6:49 pm    Post subject: Reply with quote
Twisted Evil
berin
PostPosted: Wed Oct 28, 2020 6:51 pm    Post subject: Re: No alerts/incorrect alerts Garmin 276cx Reply with quote
Code:
e.g.
I'm just downloading the PW speed camera database, which is a CSV - I think the just contains the data you mentioned
21.021 (01 Feb 23)
