Pocket GPS World :: View topic - Red light Camera warning.
T5YOB
PostPosted: Sat Jul 11, 2020 10:12 pm    Post subject: Red light Camera warning. Reply with quote
There is a red light camera in my city, the pocket GPS alert doesn't warn you when you're travelling the way the camera gets you ie past it and it looks at the rear of your car. But if you come back down the road on the other side of the carriageway going the other way it then alerts you of the camera even though it's on the other side of the road getting that side.. Any idea how to change this so it alerts when your travelling the way the camera gets you?
AliOnHols
PostPosted: Sat Jul 11, 2020 11:41 pm    Post subject: Reply with quote
Click on the Big Yellow pointy finger in the right hand margin next to this reply. On the map, find the camera in question and edit it's details.
Garmin Nuvi 2599
SatMap Active 10 & 20.
PostPosted: Sun Jul 12, 2020 8:20 am    Post subject: Reply with quote
PGPSW cameras alert whichever direction your travelling, are you sure that's not a cyclops one as those are directional? The other possibility is because you know it's there you are well under the limit so may not get the alert, travelling the other way you're driving faster so you are.
PostPosted: Sun Jul 12, 2020 9:32 am    Post subject: Reply with quote
Is speed relevant here suss as it's a REDLIGHT according to OP.
And if it is a Cyclops one, it is warming in the wrong direction. Crying or Very sad Rolling Eyes
PostPosted: Sun Jul 12, 2020 9:37 am    Post subject: Reply with quote
Is it a redlight or redspeed. I'll bet a lot don't realise the difference.
A number from the OP is needed.
Satnav:
Car Average MPG :
T5YOB
PostPosted: Sun Jul 12, 2020 10:31 am    Post subject: Reply with quote
Hi, the camera is a new Truvelo Redlight camera and speed on green, only changed from a PEEK Redlight only camera around a year ago. The Cyclops picks it up fine in the right direction. There's another redlight/speed on green camera about a mile and half down the road and gpsworld picks that up spot on. I will report it like the post above said
Cheers.
PostPosted: Sun Jul 12, 2020 12:06 pm    Post subject: Reply with quote
Next time your down there have a look at the road across the junction.
Redlight is plain but RedSpeed have horizontal white lines across the junction to help identify speeders.
If you can grab the PGPSW camera number or give us a detailed location
Satnav:
Car Average MPG :
T5YOB
PostPosted: Sun Jul 12, 2020 12:35 pm    Post subject: Reply with quote
Yep it has the three horizontal white lines just over the red stop line, also published in the local rag about being both redlight and speed on green. The old PEEK redlight cameras just used to have the tarmac coloured piezo strips in each lane over the white stop line and no white markings.
I'm not sure what you mean by camera number but when I click on the yellow hand on the right of this thread to change it the camera comes up with these details? Not sure if this is what you mean? It already has an arrow pointing in the right direction that it records offences just the alert only works when you are on the other side of the carridgeway going the other way on that road.
Hope this helps cheers.
REDSPEED:9101@40
Heading:285 (Single Direction)
PostPosted: Sun Jul 12, 2020 1:01 pm    Post subject: Reply with quote
9101 is the PGPSW ID, perfect
RedSpeed trapping WNW
Satnav:
Car Average MPG :
T5YOB
PostPosted: Sun Jul 12, 2020 4:05 pm    Post subject: Reply with quote
There's another couple further down the road towards the M1 but the alerts on those are spot on. A bit naughty those ones are though as they've set the traffic lights so they only let about 5-10 cars through if you're lucky, catches lots out especially lorries when they're 2nd or 3rd in the queue to set off they struggle to get the last half of the wagons through in time before changing..
PostPosted: Mon Jul 13, 2020 9:38 am    Post subject: Reply with quote
9101 is set correctly to alert. I've adjusted the heading slightly but unless your device uses that then it won't make a difference.
Do you have another database on the device that could be interfering?
PostPosted: Mon Jul 13, 2020 9:53 am    Post subject: Reply with quote
He is running Cyclops as well to get the best of both worlds.
@T5YOB
Have a read of post #3 again. Are you absolutely sure that sentence two is not relevant both for the problem REDSPED?
PostPosted: Mon Jul 13, 2020 10:43 am    Post subject: Reply with quote
Good point
It's a RedSpeed and Garmin, in its infinite wisdom, only recognise "Redlight" to trigger a warning regardless.
As I've mentioned before, Garmin logic is .... 'if your under the limit by a Garmin defined % and you're not accelerating' then you often won't get a warning.
The OP, knowing his area, keeps under the limit travelling NW but is not so bothered travelling SE.
Another reason to consider the Converter as that triggers a warning regardless of speed.
Satnav:
Car Average MPG :
T5YOB
PostPosted: Mon Jul 13, 2020 2:31 pm    Post subject: Reply with quote
Yes my sat nav now runs Garmin Cyclops camera alerts and the pocketGPSworld ones, that is the only camera the latter doesn't warn on though all the others it warns even if I'm under the limit.
22.034 (27 Mar 24)
