Newsletter
Luxury Villa at Watersong Davenport, Orlando, Florida for rent
Pocket GPS World :: View topic - Database not showing any Poi's Speedtrap Alert ?
billyzion
PostPosted: Mon Jul 06, 2020 8:12 am    Post subject: Database not showing any Poi's Speedtrap Alert ? Reply with quote
App has been working fine but not used for a few weeks , I've added the latest database (Speedtrap) and tried numerous others but once installed they all show 0 Poi's and a green sad face , any ideas what I'm doing wrong ??
PostPosted: Mon Jul 06, 2020 11:13 am    Post subject: Reply with quote
Can you run through how you added the latest database and in Settings - Databases, does ot show 'pocketgps_uk_sc.txt' ?
Satnav:
billyzion
PostPosted: Mon Jul 06, 2020 12:01 pm    Post subject: Reply with quote
Installed as normal (download zip file (I've tried speed alert plus others) unzipped, add database , all goes well pocket....txt is shown but with zero poi's and a sad green face
Clicking the green face gives me this error "no persistable permissions grants found for UID 11229 and Uri content://com.cxinvento......" ??
PostPosted: Mon Jul 06, 2020 1:09 pm    Post subject: Reply with quote
The links for that error don't mean a lot to me but sort of point to either a security issue or a storage issue.
Check phone free space
Check STA permissions
Satnav:
billyzion
PostPosted: Mon Jul 06, 2020 2:51 pm    Post subject: Reply with quote
Fixed it !!!
I use CX file explorer as default , deleted that and used the default file manager and all added ok
Thank you for your help xx
PostPosted: Mon Jul 06, 2020 4:23 pm    Post subject: Reply with quote
Thumbs Up
Satnav:
marksfish
PostPosted: Mon Jul 06, 2020 8:13 pm    Post subject: Reply with quote
I don't unzip the file once downloaded. I just navigate to the zip file/ appropriate file and let STA extract it.
PostPosted: Mon Jul 06, 2020 10:45 pm    Post subject: Reply with quote
I'll join the "me too" wallahs on that one mark
PostPosted: Tue Jul 07, 2020 5:25 am    Post subject: Reply with quote
Good point, neither do I.
Satnav:
billyzion
PostPosted: Tue Jul 07, 2020 8:20 am    Post subject: Reply with quote
After a bit of investigation the only way to add the database's is but using the default file manager none of the after market ones work
I'm guessing this is something to do with the last update which happens last week as it worked fine before
With the default file manager I do not have to unzip the download
I'm running the app on an unrooted Galaxy S10
PostPosted: Tue Jul 07, 2020 8:39 am    Post subject: Reply with quote
So am I, Galaxy S10
I download the latest database, that gives me a message that it has been downloaded and gives me a prompt to open it which I ignore.
I then use STA, Settings, Databases, the top "+" symbol.
That takes me to 'Downloads, Recent'.
Then I tap the pgpsw-speed ~' file (which is always top left for me), and that opens a popup box, 'select file'
I select the bottom pocket~.txt file.
That then shows me the last file and the new one and I 'remove' the old one.
Satnav:
billyzion
PostPosted: Tue Jul 07, 2020 9:08 am    Post subject: Reply with quote
Yep that's pretty much what I do however it will not work work work any file manager other than the default ??
PostPosted: Tue Jul 07, 2020 10:15 am    Post subject: Reply with quote
OK. Now for the easy way.
Email the following link to yourself
http://www.pocketgpsworld.com/modules.php?name=Cameras&op=DownloadPackage&idPackage=500
Star it (or whatever) so that the email doesn't 'get lost'.
Logon to PGPSW on your phone (The logon will stick so no need every time)
Click the link (the correct database without pMobiles) will be downloaded to your 'Downloads' folder
Now 'link' STA database settings to your downloads folder.
Long winded explanation, but a 'two/three click' update.
PS. This will only work if you are a paid up member
PostPosted: Tue Jul 07, 2020 12:08 pm    Post subject: Reply with quote
Must investigate that 'link', never noticed it.
Satnav:
PostPosted: Tue Jul 07, 2020 2:24 pm    Post subject: Reply with quote
HACKER ALERT! HACKER ALERT! WinkWinkWinkWink
20.013 (19 Jan 22)
Terms & Privacy
