Pocket GPS World :: View topic - USB power cable not supported
adamf
PostPosted: Sat May 16, 2020 5:16 pm    Post subject: USB power cable not supported Reply with quote
Can anyone recommend a USB cable that I can use between my device and a power socket to power Garmin devices I have tried lots of other micro USB cables and Garmin says it’s not supported and won’t charge thank you
PostPosted: Sat May 16, 2020 5:45 pm    Post subject: Reply with quote
Ah yes, the old third party USB cable problem.
The underlying problem can be either an underpowered USB adapter, a wrong cable that makes the Garmin think it's being connected to a PC but can't see it.
All I can say is you're best to get a Garmin TA10 or TA20 cable.
Satnav:
adamf
PostPosted: Sat May 16, 2020 6:18 pm    Post subject: Reply with quote
Thanks for the reply the issue I have is I only have one socket in the vehicle and using the supplied charger prevents me from charging other devices Garmin do do sell a USB twin socket with Cable for £25 which I’ve just found just wondering if there is any cheaper alternatives thank you..
PostPosted: Sat May 16, 2020 6:44 pm    Post subject: Reply with quote
Yes, £25 sounds expensive.
Amazon have them much cheaper, I just searched and the first hit was £6.99.
What I did was to wire a female power socket into the under dash fusebox so my wiring is hidden.
Even though they tell you not to, I coiled the cable and cable tied it to the metal end dash support which seems to be acting as a signal booster because even though only 6" of cable is visible from dash top to Garmin I'm getting 4 or 5 bars in the traffic signal display.
You can make out the coil in this WIP shot with the dash end panel off:
and the only bit of my 'traffic' cable that is visible and can 'see the sky' is this:
Satnav:
marksfish
PostPosted: Wed May 20, 2020 9:04 pm    Post subject: Reply with quote
I plug a 4 socket adaptor into my 12v supply. It runs 2x phone chargers and the Garmin. There are some around that just use usb as well, so even less room taken up.
21.034 (22 Mar 23)
