Newsletter
Pocket GPS World :: View topic - Remove Duplicates Module error in Garmin CSV to GPX Converte
Goto page Previous  1, 2, 3, 4
PostPosted: Sat May 16, 2020 8:53 am    Post subject: Reply with quote
@dales
I must hold my hand up in apology. I tried quite hard to break it, but, unlike your good self, failed miserably as I didn't know how to do it wrong. Confused
Why would anyone even think that unzipping and processing the same file more than once was a bad idea and break the A DIFFERENT prog? Much to my everlasting shame I sure didn't, so I can only congratulate you on you [s]lateral[/s] weird thinking.Very Happy
Having said all that, I was not actually talking abut the extended length of time that you took to replicate the problem once it had been found, but the length of time that the prog has been around before the problem was found. Shocked
Serious: I wonder what caused the first "13" when you installed the new version? Strange. I had no such problem.
PostPosted: Sat May 16, 2020 9:26 am    Post subject: Reply with quote
Puzzled me as well.
A fresh unzip would have removed all existing .CSV files then replaced them with good ones.
The surefire check now is that when you perform the download and unzip, or just the unzip, the first thing that should happen is 4 white boxes with no data.
If you see 4 green boxes, with data, and an enabled Process button then Houston you have a problem. You should only see the 4 green boxes after a 'process' not before.
Satnav:
jonial
PostPosted: Sat May 16, 2020 9:35 am    Post subject: Reply with quote
I am as puzzled as you three are. I have been trying to remember in what order I pressed buttons when the problem appeared to me last weekend, but I can't remember.
I promise to be more careful in the future !!!
Jonial
Garmin Nuvi 2547LM
CamerAlert
PGPS Speed Cameras
PostPosted: Sat May 16, 2020 11:29 am    Post subject: Reply with quote
I would try to break it.
What you did should not be possible now. It was a definite bug under the right order.
Satnav:
Page 4 of 4
20.054 (25 May 22)
