JoeGriffin Occasional Visitor
Posted: Sat Sep 07, 2019 5:39 pm Post subject: Shaping points of DriveSmart |
I have discovered an oddity on the Drive models.
Often I will set up a route, using specific locations in order to go the way I want, rather than let the SatNav choose. I recently discovered that if I set the locations (which I have stored in a custom "Routing" POI file) as Via points, then all is well but if, in Trip Planner I change them to shaping points, then often the SatNav will move them to another, nearby location, which may not even be on the same road!
As an example, I wanted to travel from Mannings Heath (south of Horsham) to Charlwood, via the M23. I set two via points. The Black Swan pub at Pease Pottage (to force my route up Grouse Road) and the Gatwick Spur off the M23. This worked fine until I changed them from Vias to Shaping points. After that, the Black Swan point moved over onto the A23, just before the start of the M23 and my route went from Mannings Heath, south on the A281, across though Lower Beeding to Handcross and up the A23, completely missing The Black Swan!
This behaviour does NOT occur on the Nuvi 2599 but does on both my DriveSmart 50 and DriveSmart 51. Has anyone else seen this? _________________ ... Joe
Garmin Montana 600
Garmin DriveSmart 51LMT-D
Garmin Nuvi 2599LMT-D
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4399 Location: West Sussex
Posted: Sat Sep 07, 2019 6:20 pm Post subject: |
Strange, I have a DS50 and haven't seen that issue. Only thing I can think of that may cause it is if the map was different, maybe a route created on an earlier map version then the change made on the current map? _________________ Where there's a will ... there's a way. |
Posted: Sun Sep 08, 2019 12:44 am Post subject: |
sussamb wrote: | Only thing I can think of that may cause it is if the map was different, maybe a route created on an earlier map version then the change made on the current map? |
No, I created the route in Trip Planner on the DS50/51, then (before saving) I did a "back" and clicked on the intermediate points to change them to shaping points. After clicking "Next", the points had moved and the route changed. Same on both the DS50 and DS51 but not on the 2599.🤔 _________________ ... Joe
Garmin Montana 600
Posted: Sun Sep 08, 2019 6:39 am Post subject: |
You might try a master reset to see if that resolves it. I'll try duplicating that behaviour later though on my DS50, but am heading out right now to help marshal a tri-athlon. _________________ Where there's a will ... there's a way. |
Posted: Sun Sep 08, 2019 10:42 am Post subject: |
OK, tried that and I get the same result, so it certainly seems like a bug. Interestingly when you convert them back to viapoints they remain where the moved shaping points were. Convert them again to shaping points and they move again.
Worth contacting Garmin on this. _________________ Where there's a will ... there's a way. |
Posted: Tue Oct 01, 2019 6:15 pm Post subject: |
I passed this on to a contact of mine in Garmin, who contacted their automotive department who said if they get more reports they'll look into it! I've emailed product support but would probably help if you, or anyone else with a Drive model, does the same. _________________ Where there's a will ... there's a way. |
Posted: Wed Oct 02, 2019 11:46 pm Post subject: |
sussamb wrote: | I passed this on to a contact of mine in Garmin, who contacted their automotive department who said if they get more reports they'll look into it! I've emailed product support but would probably help if you, or anyone else with a Drive model, does the same. |
Thanks, Suss. Do you have an email for product support.
Cheers, _________________ ... Joe
Garmin Montana 600
Posted: Thu Oct 03, 2019 6:44 am Post subject: |
[email protected] _________________ Where there's a will ... there's a way. |
Posted: Thu Oct 03, 2019 6:59 am Post subject: |
Report sent in _________________ ... Joe
Garmin Montana 600
Posted: Thu Oct 03, 2019 8:38 am Post subject: |
Great, I've just sent in screenshots and a route at their request so hopefully it'll be fixed at some point. _________________ Where there's a will ... there's a way. |
Posted: Thu Oct 03, 2019 8:25 pm Post subject: |
They've tested it and can't reproduce it, so have asked for a video which I've now made and sent in. _________________ Where there's a will ... there's a way. |
Posted: Fri Oct 04, 2019 2:48 pm Post subject: |
sussamb wrote: | They've tested it and can't reproduce it, so have asked for a video which I've now made and sent in. |
Wow! I'm glad they haven't asked me for that. _________________ ... Joe
Garmin Montana 600
M8TJT The Other Tired Old Man
Posted: Fri Oct 04, 2019 7:19 pm Post subject: |
But they know that suss is a smart ass.  |
Posted: Fri Oct 04, 2019 10:42 pm Post subject: |
Kremmen Pocket GPS Verifier
Joined: Mar 03, 2006 Posts: 6647 Location: West London & Reading
Posted: Sat Oct 05, 2019 3:28 am Post subject: |
Depends what sort of video Suss has sent in
I must admit, I had loads of problems using Basecamp so I use Mappoint, now obsolete, to do my routing and shaping. It just works so much better.
Basecamp isn't user friendly for me. _________________ Satnav:
Viofo A119 V3 |
