Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 60, 61, 62 ... 72, 73, 74  Next
dales
PostPosted: Sun Feb 03, 2019 10:30 am    Post subject: Reply with quote
Thanks K.
I get logged-in automatically to PGPSW every time, no problem.
The database check works just fine. It goes green instantaneously and the run commences, but then the run halts after a variable amount of processing has been done.
Yes I download the database with the program.
Dales.
PostPosted: Sun Feb 03, 2019 10:45 am    Post subject: Reply with quote
Kremmen wrote:
There is still an unexpected error if the 'pocketgps_uk_sc.csv' gets accidentally left behind, now trapped, can't hurt.
Yes, I can see that K, but my problem was not with that file, but a 'comments' file that we have been playing with for some time that somehow got into my converter working folder. RED FACE emoicon.
PostPosted: Sun Feb 03, 2019 10:53 am    Post subject: Reply with quote
Done, as per above:
Latest version is 3rd Feb 2019.
Version 2019.02.03.81:
**Download CSV Converter (Latest Version) **
The error message produced in the database check area is now more meaningful and will help me determine which part of the module has the error.
The MessageBox also contains a reference to the module location that I need, thanks.
Satnav:
Car Average MPG :
dales
PostPosted: Sun Feb 03, 2019 11:11 am    Post subject: Reply with quote
New program installed - gives extra error messages !
The usual Error number 5, plus
Unable to match the latest PGPSW database version against the installed version.
Please post this error - Debug - Before PGPSW check.
(As usual, the Direction Converter throws no errors and checks the database OK).
Dales.
PostPosted: Sun Feb 03, 2019 11:20 am    Post subject: Reply with quote
OK let me check any code differences ...........
Satnav:
Car Average MPG :
PostPosted: Sun Feb 03, 2019 11:24 am    Post subject: Reply with quote
CSV Converter:
Dim request As WebRequest = WebRequest.Create("https://www.pocketgpsworld.com/modules.php")
Using response As WebResponse = request.GetResponse()
Using reader As New StreamReader(response.GetResponseStream())
Dim responsetext As String = reader.ReadToEnd()
File.WriteAllText(WorkingFolder & "\Latest.txt", responsetext)
End Using
End Using
Direction Converter:
End Using
End Using
Identical.......... Hmmm
Satnav:
Car Average MPG :
dales
PostPosted: Sun Feb 03, 2019 11:49 am    Post subject: Reply with quote
To be clear - the CSV Converter checks my database version immediately, and reports its status (current or out-of-date).
After that, I click the green Process button and processing commences. Some (variable) time later the processing halts, and after a few more seconds it issues the error message described.
So it's not the initial database check that's failing - it's something afterwards.
Dales.
PostPosted: Sun Feb 03, 2019 11:51 am    Post subject: Reply with quote
Can you download and run this version.
More error messages for each instance. I'm looking around TechNet and they all seem to indicate a failed connection.
So does it display the correct 'database current' message at program start or is it only after you perform another action ?
Satnav:
Car Average MPG :
PostPosted: Sun Feb 03, 2019 12:04 pm    Post subject: Reply with quote
I've spotted a possible candidate for change.
Still test the beta version but I'm going to make a change to the call.
Satnav:
Car Average MPG :
dales
PostPosted: Sun Feb 03, 2019 12:11 pm    Post subject: Reply with quote
Yes at program start it correctly reports the database status.
The latest version has failed, although it got 80% through, which is further than most attempts.
The error message is as above, except that the last line now reads
Please post this error - Debug - Before using 1.
Dales.
(I've got to go out now for about 3 hours).
PostPosted: Sun Feb 03, 2019 12:22 pm    Post subject: Reply with quote
I think I've found it.
Can you download the latest from the main link:
Satnav:
Car Average MPG :
dales
PostPosted: Sun Feb 03, 2019 2:19 pm    Post subject: Reply with quote
That's it ! Great stuff.
Many thanks,
Dales.
PostPosted: Sun Feb 03, 2019 2:48 pm    Post subject: Reply with quote
Thumbs Up
Satnav:
Car Average MPG :
PostPosted: Mon Feb 04, 2019 12:25 am    Post subject: Reply with quote
Then why was I not getting the same or similar error K?
PostPosted: Mon Feb 04, 2019 6:13 am    Post subject: Reply with quote
I'm guessing it was an internet speed issue.
The error I found, eventually, would have caused a number of rapid calls to here to get the database date.
I don't know what speed Dales has but I'm on a real 24/4Mbps.
It now only looks for the date on first program load and after you unzip the package. I also had it checking in another module that is frequently called.
Satnav:
Car Average MPG :
Page 61 of 74
22.051 (01 May 24)
