spikem Occasional Visitor
Posted: Fri Oct 19, 2018 11:18 pm Post subject: Garmin Drive series |
If you have the UK / ROI version of a Drive assist series that only has voice control , will this change to voice command if you update the map to a full Europe version. |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4454 Location: West Sussex
Posted: Sat Oct 20, 2018 10:03 am Post subject: |
Good question but no idea _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
Posted: Sat Oct 20, 2018 10:46 am Post subject: |
What's the difference ? _________________ Satnav:
Car Average MPG :
Warthen Occasional Visitor
Posted: Mon Dec 03, 2018 12:14 pm Post subject: |
spikem wrote: | If you have mastered compound bows and the UK / ROI version of a Drive assist series that only has voice control , will this change to voice command if you update the map to a full Europe version. |
It shouldn't matter if you upgrade it or not, right? It should still preserve its functionality. But I don't have it so I'm just guessing essentially.
b33jay Lifetime Member
Posted: Mon Dec 03, 2018 5:44 pm Post subject: |
Not sure what the Op is asking but does a device sold as UK & Ireland have sufficient memory to be updated to a full (or even part) Europe map base?
The 2589 loses some commands if the original all Europe map is changed to a smaller map base to overcome the lack of memory. Commands to set up a route are no longer available and are restricted to history, favourites and Four Square only |
Posted: Mon Dec 03, 2018 6:37 pm Post subject: |
[quote="b33jay"]Not sure what the Op is asking but does a device sold as UK & Ireland have sufficient memory to be updated to a full (or even part) Europe map base?
[/quotes]
Maybe not on board but it certainly can be by using a SD card. I upgraded my 2508 in exactly that way. _________________ Where there's a will ... there's a way. |
