Posted: Wed Jun 06, 2018 6:47 pm Post subject: Map Update to 2019.20 available
8.03 GB for the full map set
File size changes (for full Europe are as follows)
Gmapprom.img increases from 2,693,552 to 2,286,592
D6210050A.img (secondary file) increases from 2,171,712 to 2,205,888
Junction view files (North and South) increase to 215,627 and 187,272 respectively _________________ DriveLuxe 51 LMT D - Firmware 6.20
Previously owned: DriveLuxe 50 LMT-D, NuviCam LMT-D, Nuvi 3598 LMT-D, Nuvi 3490LMT, 3790T, 1690, 765, 760, 660, 610, 360, 310, 300 and Streetpilot i3
Users with gmapdem, beware. This version deletes the gmapdem disc image file (but not the sum file); make sure that you have a backup ready. _________________ Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6.
Joined: Mar 18, 2011 Posts: 4394 Location: West Sussex
Posted: Thu Jun 07, 2018 7:02 am Post subject:
Very few devices have that file, I suspect those that do are well used to it being deleted. It's a reminder though that we should all back up our devices before we update, I do it for every device and not just my Garmins. _________________ Where there's a will ... there's a way.
Joined: Mar 03, 2006 Posts: 6630 Location: West London & Reading
Posted: Thu Jun 07, 2018 7:24 am Post subject: Re: Map Update to 2019.10 available
2 of those are decreases _________________ Satnav:
Posted: Fri Jun 08, 2018 2:37 pm Post subject:
Before I update my 2699 is it safe being as a file is reported as missing ? _________________ Satnav:
Posted: Fri Jun 08, 2018 4:26 pm Post subject:
Ta
I did the 2599 earlier so the files are saved for the 2699 = a 20 minute job.
I solved the download size issue a few months ago by installing a new bigger C:/ SSD. No shortage of Gb now. _________________ Satnav:
Just updated my 3598.
Took about half an hour.
Booting takes more than 30s
Front screen finally appears.
Freezes when "Where To" and "Maps" is pressed.
Does not go to the next screen - just hangs.
Nothing happens.
Currently trying to reinstall map via option on Garmin Express.
Thanks sussamb, to my great relief the reinstall worked.
However, as MichaelCahill mentions above, in my case the gmapdem disc image file was also missing and I had to copy it from my backup.
Maybe if it is replaced or not depends on which Garmin server the update comes from?
Joined: Dec 17, 2006 Posts: 287 Location: Ellesmere UK
Posted: Wed Aug 29, 2018 1:32 am Post subject:
I updated this evening, not without traumas. Once the maps and new software were installed the unit kept freezing after I had gone through the calibration process. I was asked to accept the massive ELUA but it froze at that point. I had to cold start several times before I was able to proceed.
Then I found I had lost my favourites for the first time in years. Not critical but annoying. I now find that the previous very clear speed limit sign has been replaced by a less distinct rectangle with, subjectively smaller numbers. If it ain't broke then don't fix it!
Grrrrr
Gmapprom.img increases from 2,286,592 to 2,381,952
D6210070A.img (secondary file) increases from 2,205,888 to 2,237,120
Junction view files (North and South) increase to 216,277 and 187,312 respectively _________________ DriveLuxe 51 LMT D - Firmware 6.20
Page 1 of 5
