Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 49, 50, 51 ... 72, 73, 74  Next
PostPosted: Fri Aug 04, 2017 7:45 pm    Post subject: Reply with quote
Metblackrat wrote:
Is this compatible with the European cameras?
No.
I've just tried it with the Europe, speed zoned complete and it throws up a load of errors. I'm guessing it's to do with the higher speed limits as they are stated in KMH.
And the fact that a lot are none UK speeds
Is this something for a future release maybe?
Who knows, but a lot of work for Kremmen to do. Very Happy
PostPosted: Sat Aug 05, 2017 5:52 am    Post subject: Reply with quote
Yes, it would be a big change as I currently only work with MPH.
It would probably be easier to copy the existing code and convert it into a 'EU CSV to GPX Converter'
A Winter project maybe.
Satnav:
Car Average MPG :
PostPosted: Tue Aug 08, 2017 7:04 am    Post subject: Reply with quote
The latest zip package now contains both female and male voice packs.
Same link.
If you wish to change to male warnings then just unzip the package and copy/paste the .wav files over the female ones you currently have in the Working Folder.
Satnav:
Car Average MPG :
PostPosted: Thu Oct 05, 2017 11:21 am    Post subject: Reply with quote
New version:
2017.10.05.65
This version adds 2 options when processing is complete:
Option 1 'Finish' - As now, just cleans up, saves your settings and leaves the Converter open for viewing statistics and/or changing the warning text.
Option 2 - 'Finish & Launch POILoader' Cleans up, saves settings, closes the Converter and auto launches Garmin's POILoader.
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=0
Satnav:
Car Average MPG :
PostPosted: Fri Oct 06, 2017 6:54 am    Post subject: Reply with quote
I've included a POILoader launch button on the main menu.
At this stage that's all it does. Depending on feedback ..........
Version 2017.10.06.66
Satnav:
Car Average MPG :
PostPosted: Fri Oct 06, 2017 7:02 am    Post subject: Reply with quote
For those of us wishing to update is there a simple way, eg one file to copy, to do so or do we need to do a complete uninstall and reinstall? In the past that's what I've done but can I just replace an .exe file?
PostPosted: Fri Oct 06, 2017 7:08 am    Post subject: Reply with quote
Not tried just replacing the exe so I don't know the consequences.
Given that the exe is buried in your user area in that apps2 folder, twice, it's probably more hassle anyway.
I always do the full thing as it only takes minutes.
Satnav:
Car Average MPG :
PostPosted: Fri Oct 06, 2017 7:14 am    Post subject: Reply with quote
Cheers, may be minutes for you as you're doing it more often than me, takes me a bit longer!
PostPosted: Fri Oct 06, 2017 7:30 am    Post subject: Reply with quote
Still minutes though, I didn't specify 2 or 99 Laughing
Satnav:
Car Average MPG :
PostPosted: Fri Oct 06, 2017 7:32 am    Post subject: Reply with quote
Laughing
PostPosted: Thu Nov 02, 2017 7:57 am    Post subject: Reply with quote
Voices addition.
I've noticed that CamerAlert has a different WAV for the RedSpeed cameras.
My current voicepack has a homebrew:
"RedSpeed camera xx miles per hour", created by me.
CamerAlert has:
"Redlight and speed camera xx miles per hour".
You now have a choice.
The default 'voicepack' still has "Redspeed" but there is now a new pack with the CA version, your choice:
Usual link
Satnav:
Car Average MPG :
PostPosted: Wed Nov 15, 2017 12:06 pm    Post subject: Reply with quote
Purely Beta, to see how it goes.
I've put 3 help buttons in:
When you click the static button, it should open the .mht Helpfile at the exact position of the valid topic.
One snag I've found is that Internet Explorer doesn't close immediately every time so in most occasions it's a one off check. Then you may need to wait up to 20 secs for IE to close before another button will work.
[link removed- backed out]
Just 3 to start with as I'm not 100% convinced given the delay.
Satnav:
Car Average MPG :
PostPosted: Wed Nov 15, 2017 8:09 pm    Post subject: Reply with quote
I expect peeps who use IE are used to all sorts of delays K so won't notice/worry about it.Rolling Eyes
I'll give it a whirl later.
PostPosted: Thu Nov 16, 2017 5:29 am    Post subject: Reply with quote
Ta
If it gets a seal of approval I can extend it with more buttons if needed.
or
Strip it out as failed.
Satnav:
Car Average MPG :
PostPosted: Thu Nov 16, 2017 9:18 pm    Post subject: Reply with quote
Doesn't open help file for me. Asks to find app in Store. So obviously I haven't got the right whatever to open .mhtml nor will any other W10 people by default.
Page 50 of 74
