spaceprobe Occasional Visitor
Posted: Fri May 19, 2017 5:13 pm Post subject: Shutting down on android 7 |
I cant find an answer anywhere and my speed cam app as now become unusable. Since the update to Android 7 the app runs for a bout 10 minutes then shuts off. I have gone into battery saver etc and made sure that is not the issue it just wont play ball |
Kremmen Pocket GPS Verifier
Posted: Fri May 19, 2017 6:26 pm Post subject: |
Not universal with Nougat because it stays alive on my HTC One m9
Have you checked Nougats new 'optimise' settings as that could be shutting it down. If you have a HTC then check Boost+ as that does a similar trick of shutting apps it thinks aren't open/running.
I know Norton had to update it's Android app because Nougat optimise was shutting it down = oops. _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
Posted: Fri May 19, 2017 7:37 pm Post subject: |
Are you running it in the foreground or background? |
abre Occasional Visitor
Joined: Jan 30, 2013 Posts: 45 Location: Saddleworth, Yorkshire :o)
Posted: Sat May 20, 2017 9:00 am Post subject: |
Same as I said then _________________ Satnav:
Car Average MPG :
Posted: Sat May 20, 2017 10:00 am Post subject: |
Yes... |
GazzaW Occasional Visitor
Posted: Sun Jun 02, 2019 12:59 pm Post subject: Re: Shutting down on android 7 |
spaceprobe wrote: | I cant find an answer anywhere and my speed cam app as now become unusable. Since the update to Android 7 the app runs for a bout 10 minutes then shuts off. I have gone into battery saver etc and made sure that is not the issue it just wont play ball |
I have a OnePlus 6 running Android Pie. I have unoptimised Camera Alert and have 4GB free memory but the app stops running after 5 - 10 minutes meaning it's basically useless. There is a warning when installing the app that it's not optimised for Android Pie and may not run properly! The app needs to be updated so it's fully supported for Pie and doesn't get stopped by Android |
Posted: Fri Jun 14, 2019 4:19 pm Post subject: |
Have a read of THIS and set CA to 'Active'. I think that should work |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15142 Location: Bradford, West Yorkshire
Posted: Fri Jun 14, 2019 9:33 pm Post subject: |
M8TJT wrote: | Have a read of THIS and set CA to 'Active'. I think that should work |
CamerAlert shows as 'EXEMPTED' and is not selectable on my OnePlus 5 (Pie).
However, I generally have it in the foreground with Google Maps overlaid in the corner.
Posted: Fri Jun 14, 2019 10:51 pm Post subject: |
Strange, I was able to set it on my S9+ Pie. |
