Pocket GPS World :: View topic - Directional Warnings for GPX Converter
PostPosted: Fri Feb 03, 2017 2:52 pm    Post subject: Reply with quote
Version 15 is available.
A bug has been found when the GPX Converter Text Change screen was used with data from the Direction Converter.
If this is a feature you use then you will need both programs:
GPX Converter (Latest):
https://www.dropbox.com/s/4kpnpbwlk6k2e78/CSV%20to%20GPX%20Installer.zip?dl=1
Direction Converter (Latest):
*** Download Latest Version ***
PostPosted: Wed Nov 21, 2018 5:05 pm    Post subject: Reply with quote
New version:
2018.11.21.16
This version incorporates the check for the database date and will prompt you to download the latest if it's over a week old.
I've only given it developer testing, ran out of time, but I'm sure you'll let me know.
PostPosted: Thu Nov 22, 2018 9:44 am    Post subject: Reply with quote
Yet another update ....
The inbuilt legacy UnZip routine was throwing a .COM error for some. Looks like maybe Microsoft have changed something in the year since the last version.
I've replaced it with the latest .NET routine that is (should be) more robust.
Version 2018.11.22.17:
PostPosted: Sun Dec 02, 2018 1:37 pm    Post subject: Reply with quote
Update:
After feedback - I've changed the database check to obtain the latest published version 'live' from the PGPSW site.
It will check the installed database and after comparison will prompt you to update.
To get more information hover your mouse over the information box:
Version 2018.12.02.18:
PostPosted: Mon Dec 03, 2018 1:05 pm    Post subject: Reply with quote
Code applied to mimic the CSV to GPX Converter:
Once you install this version it 'should' be the last time you are prompted to select your 'Working Directory' upon a fresh install.
Version 2018.12.03.19:
PostPosted: Mon Dec 03, 2018 4:20 pm    Post subject: Reply with quote
Nice one K.
Save me fiddling about with file explorer when I do your W10 testing Very Happy
PostPosted: Mon Dec 03, 2018 6:08 pm    Post subject: Reply with quote
Very Happy
toyracer69
PostPosted: Wed Dec 05, 2018 3:05 am    Post subject: Reply with quote
I'm getting the files not the down load again Kremmen. Wink
PostPosted: Wed Dec 05, 2018 5:51 am    Post subject: Reply with quote
I've changed the download link.
It looks like Dropbox made some changes back in March:
https://www.dropboxforum.com/t5/Sharing-and-collaboration/quot-Direct-download-quot-links-are-not-working/td-p/211900
All I did last time was change the "dl=0" to "dl=1", which I've done again to the last download link above.
Reading the link it may be just IE affected ?
PostPosted: Wed Dec 05, 2018 10:50 am    Post subject: Reply with quote
Works for me K. Now just gets on with the download rather than having to ponce around with whether to download or save to Dropbox.
Incidentally, those posts you referenced were 2017 not this year.
PostPosted: Wed Dec 05, 2018 11:09 am    Post subject: Reply with quote
Just checking you were awake ............ whilst I was asleep Smile
toyracer69
PostPosted: Wed Dec 05, 2018 6:34 pm    Post subject: Reply with quote
All working correctly again and this was via Chrome. Wink
PostPosted: Wed Dec 05, 2018 7:52 pm    Post subject: Reply with quote
I've changed the download links in both programs now to perform a direct download from Dropbox.
PostPosted: Thu Dec 20, 2018 3:28 pm    Post subject: Reply with quote
New Version:
As previously mentioned, I've had to update the .Net version from 4.5 to 4.7
This is for full Win10 compatibility.
Note: If you haven't got .Net 4.7 (Non Win10) you will be prompted to download it and it should provide a Microsoft link.
Whilst testing a few cosmetic items have been changed:
1) When the base CSV backup files are available the recovery button is highlighted green.
2) If you closed the program prematurely and reopened it, it would delete the processed CSV files. It now retains them and only the subsequent run of the CSV Converter will remove them as they get converted to GPX.
Version 2018.12.17.20:
Thanks to M8TJT for putting this program through it's paces.
PostPosted: Fri May 15, 2020 3:41 pm    Post subject: Reply with quote
New version 15th May 2020
Bugfix:
The program was not deleting CSV files on an unzip so if you accidentally downloaded, unzipped, processed, then unzipped and processed again it was appending to the existing CSV file(s).
Fixed:
*** Download Latest Version 22 ***
Page 2 of 3
23.034 (26 Mar 25)
