jwmachon Occasional Visitor
Posted: Fri Dec 30, 2016 9:04 am Post subject: PGPSW on GARMIN 50 LMT-D Questions please |
Im thinking of getting a 50 LMT-D sat nav and installing the pgpsw database.
At the moment i use cameralert on android but having to do away with that
I have a couple of questions
1) When approaching a speed camera what warning will i get
2) if i go over speed limit during camera what warning will i get
3) in a average speed camera zone does it tell me if i go over 50 for example
4) is it directional like cameralert
many thanks,
Jonny |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4456 Location: West Sussex
Posted: Fri Dec 30, 2016 9:16 am Post subject: |
1) Depends on how you install it. Using Kremmens convertor I get a voice that warns me of the camera along with it's speed at a distance you can set.
2) Not sure. Mine is set to only give one warning as it's all I need.
3) No
4) Can be I believe with some extra work, I don't bother
It also can't drive the car for you ... so I'm afraid having been warned you as the driver need to take action IF you're going too fast _________________ Where there's a will ... there's a way. |
M8TJT The Other Tired Old Man
Posted: Fri Dec 30, 2016 9:26 am Post subject: |
Just to add to Sus's answer to 4. It's not directional as in CA, but you can set it up, with yet another oiece of softwate to give an alert such as "Fixed Speed Camera, 30 Miles Per Hour, West" Telling you which direction the camera is trapping.
It's a bit of a faff to initially set up the process, but once you have done it a couple of times, it only takes a couple of mins. Nowhere as easy as CA though, but well worth it. The default Garmin just gives a quiet bong and a blue dot indicating the cam's position, not to mention multiplke alerts for overspeed ac co-located cams (both ways on M/W gantry). |
Posted: Fri Dec 30, 2016 9:38 am Post subject: |
Thanks guys I would of like a warning if I go over speed limit by accident whilst approaching or going past camera after initial warning mistakes do happen I though there was a overspeed warning |
Posted: Fri Dec 30, 2016 11:04 am Post subject: |
jwmachon wrote: | I approach a speed camera and go above speed limit will it warn me that im above the limit till I slow down | Yes it will if you want it to. The overspeed warning time is adjustable in Kremmens CSV-GPX converter. Quote: | and also how does it work going through specs | It doesn't calculate and display your average speed, if that's what you mean. It just tells you there is a SPECS camera there.
Using Kremmen's software gives an overall much better experience that the bog standard Garmin alerts with only a blue dot on the screen and a quiet bong. Kremmen's prog puts 'proper' icons on the screen, spoken alerts, and no multiple alerts for the same and adjacent cams (unless you set an overspeed alert, which you seem to want to do). The Garmin speed cam offering is really quit poor in its implementation. |
Kremmen Pocket GPS Verifier
Posted: Fri Dec 30, 2016 11:21 am Post subject: |
A recent idea I put into the Converter was an adjustable overspeed warning limit.
Garmin sometimes is a bit too keen to warn you, again, when you are even slightly under the limit so you can, say, set the overspeed for a 50mph camera to trigger at anything up to 57mph, but no more, (10% + 2mph for those that like to gamble). _________________ Satnav:
Car Average MPG :
Posted: Fri Dec 30, 2016 11:50 am Post subject: |
Shame we can't trap the alerts and UI to make our own SPECS calculations as you can do on iGO. |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Fri Dec 30, 2016 6:31 pm Post subject: |
Also considering getting a Garmin 50 LMT-D after many years with TomTom. Can the Garmin be set to warn for cameras "only on route" when using Kremmen's program and the PGPS world cameras? _________________ Paul |
Posted: Fri Dec 30, 2016 7:05 pm Post subject: |
No. |
Posted: Fri Dec 30, 2016 7:07 pm Post subject: |
Ok. Thank you for the reply. _________________ Paul |
Posted: Fri Dec 30, 2016 7:25 pm Post subject: |
But you won't get many warnings for off route cameras. _________________ Where there's a will ... there's a way. |
Posted: Fri Dec 30, 2016 7:51 pm Post subject: |
That's good news. The off route cameras can be a bit distracting.
I'm trying to work out if I am going to like the Garmin before buying one. The newer TomTom's don't have the features I want.
I would like something thinner than my old TomTom GO710 as I want to mount it on a Brodit Proclip in my new car. _________________ Paul |
Posted: Sat Dec 31, 2016 6:14 am Post subject: |
You can mount all Garmins on a ProClip ....
Assuming you can still get the Brodit ball mount. I've got one in stock just in case.
What it is is a small chunky 1" piece of plastic with a 4 hole backplate and the Garmin ball on the other end.
Yep, DSLDevelopments, item number 215547 _________________ Satnav:
Car Average MPG :
Posted: Sat Dec 31, 2016 10:12 am Post subject: |
Thank you Kremmen, that looks ideal. _________________ Paul |
b33jay Lifetime Member
Posted: Tue Jan 03, 2017 5:51 pm Post subject: |
Buy a cheap vent mount and remove the clips then either drill it or use double sided tape.
http://tinyurl.com/zotzynm |
