Pocket GPS World :: View topic - Speed camera database needed in .fbl file format - Mio M420
mikec2016
PostPosted: Wed Jun 08, 2016 3:46 pm    Post subject: Speed camera database needed in .fbl file format - Mio M420 Reply with quote
Hi, Does anyone know how to get hold of a database of speed cameras in .fbl file format. Is it available on PocketGPS? It is needed for a Mio M420. Thanks a lot. Mike
PostPosted: Wed Jun 08, 2016 4:35 pm    Post subject: Reply with quote
You sure about the file type Mike? .fbl is the extension used for iGO map files. If it's iGo that you're wanting cams for, they are in .txt format and are available from here. Mio used to use iGO software.
Don't know about the other two cars that you are asking about. It would be useful if you could specify the SatNav type (Manufacturer: TomTom, Garmin, iGO etc.) here.
mikec2016
PostPosted: Fri Jun 10, 2016 10:31 am    Post subject: Maps database needed in .fbl file format - Mio M420 Reply with quote
Thanks for your reply. I made a mistake in my post - it is the updated maps I am needing for the Mio M420. They are in .fbl format which makes sense form what you say. Do you know where I can get an update please? To install, will it be a simple matter of replacing the appropriate .fbl file in the satnav data files? Thanks for your help, Mike
PostPosted: Fri Jun 10, 2016 10:38 am    Post subject: Re: Maps database needed in .fbl file format - Mio M420 Reply with quote
The only official way is via Naviextras. There are other places, but we don't talk about pirating here.
To install, will it be a simple matter of replacing the appropriate .fbl file?
Yes, it's that easy, but it's best if you have a 'matching set' (.fbl, .ftr etc. from the same year/Quarter) of files, especially if you are truck orientated.
Speed camera files are available from here in the .txt format required for iGO based software if you are a subscriber.
mikec2016
PostPosted: Fri Jun 10, 2016 10:43 am    Post subject: Reply with quote
Brilliant! Thank you!
Mike
22.051 (01 May 24)
