Pocket GPS World :: View topic - CSV to GPX warning on file type
Wizzardoz
PostPosted: Sat Apr 30, 2016 7:55 am    Post subject: CSV to GPX warning on file type Reply with quote
I am using the latest software for CSV to GPX
Garmin PoiLoader downlad
UK - Spped Zone Complete
Wav - Female with Chime Prefix
The CSV to GPX on processing, gives an error "Invalid file format - Filenames shouls not have number in them"
I did not have this warning with earlier version of CSV to GPX. Any idea on this error please?
PostPosted: Sat Apr 30, 2016 8:29 am    Post subject: Reply with quote
That warning is telling you that the CSV files have a format of say 'gatso_50.csv' instead of the required 'gatso_fifty.csv'
This is usually due to unzipping the main file via Windows instead of using the programs built in unzipper that also performs other pre actions.
If you have used the programs unzip facility then look for a rogue file that has a numeric in it - and delete it.
Satnav:
Car Average MPG :
Wizzardoz
PostPosted: Sat Apr 30, 2016 8:34 am    Post subject: Reply with quote
Strange. I used a 7/2015 version of CSV to GPX and used winzip to extract. There are no issues there.
Wizzardoz
PostPosted: Sat Apr 30, 2016 8:36 am    Post subject: Reply with quote
Also the 2015 software created a *.gpi file but I cannot locate it.
**** Ignore - now located it.********
Wizzardoz
PostPosted: Sat Apr 30, 2016 9:00 am    Post subject: Reply with quote
Kremmen, your suggestion works but am still curious as to why winzip does not work with the latest version.
Many thanks for your prompt response above.
Wizzardoz
PostPosted: Sat Apr 30, 2016 9:07 am    Post subject: Reply with quote
Just created the files and loaded them with POI loader to Garmin 2699 SD card. The POI folder still shows a March 2016 file although the transfer appeared to be correctly created.
PostPosted: Sat Apr 30, 2016 11:11 am    Post subject: Reply with quote
Winzip extracts the files exactly as they are in the .zip file. The filename format is incorrect for the converter. If you have a number in the file, POI Loader treats it differently. So whilst the converter unzips the .zip file it also renames them to the correct format (amongst other things). That's why. Very Happy
PostPosted: Sat Apr 30, 2016 12:42 pm    Post subject: Reply with quote
Ta
Been out so missed the recent posts.
Satnav:
Car Average MPG :
