Kremmen Pocket GPS Verifier
Posted: Sun Jul 12, 2015 6:34 pm Post subject: |
We are talking Windows here so normal logic goes straight out of the door _________________ DashCam:
Car Average MPG :
Allan_whoops Frequent Visitor
Posted: Mon Jul 13, 2015 7:06 am Post subject: |
I've been here with other software including Garmin Express!
Right click on the installer, go down to properties - click on that.
Click on the Compatibility tab.
Tick the box and choose your version from the drop down list.
Apply,
OK
and you should be. |
cliffbrown Lifetime Member
Posted: Wed Jul 15, 2015 8:29 pm Post subject: |
Hi all thanks for your input I am up and running, having converted from the dark side I need to get used to the very different layout but must persivere and need to tweek the settings thanks again |
Posted: Thu Jul 16, 2015 4:59 am Post subject: |
I haven't made any changes since 2013 because it works.
I do have a couple of small tweaks I want to make but that's a job for winter. I need to rebuild a spare PC because I need to test the Visual Studio installer on a clean PC as I've lost InstallShield now.
I'm looking at saving the last camera count to show the increase/decrease, just for info. That will only be of use if you process the same camera types.
Also trying to determine whether sox.exe is loaded correctly and display it in the bottom bar.
Look at the popup explanations when you hover over a dialogue field. _________________ DashCam:
Car Average MPG :
Posted: Thu Jul 16, 2015 1:54 pm Post subject: |
sorry Kremmen I need to do a few tweaks, thanks again |
Posted: Thu Jul 16, 2015 3:26 pm Post subject: |
My program tweaks will be different to the usage tweaks. _________________ DashCam:
Car Average MPG :
M8TJT The Other Tired Old Man
Posted: Thu Jul 16, 2015 6:57 pm Post subject: |
Wacha tweakin Krem? |
Posted: Fri Jul 17, 2015 4:51 am Post subject: |
Four posts up _________________ DashCam:
Car Average MPG :
Posted: Mon Jul 20, 2015 10:27 am Post subject: |
In testing:
Car Average MPG :
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 494 Location: South Yorkshire
Posted: Tue Jul 21, 2015 6:33 pm Post subject: |
some nice additions there
also might be an idea to get this stickied with you main app so easily found on the page |
Posted: Wed Jul 22, 2015 4:56 am Post subject: |
One tiny snag.
Now that I have no access to the full Visual Studio and InstallShield I can only create ClickOnce applications.
No big deal really as it works, just slightly differently.
It installs to the users data area and places a shortcut on the desktop. Basically nothing to do with Windows installer.
I have a test PC that I will be installing it on because I want to make sure it checks and downloads dot net 4 if not found and how much of the work folder needs to be included in the install package. I doubt if the setup.exe is enough on its own. _________________ DashCam:
Car Average MPG :
ashley750 Occasional Visitor
Posted: Thu Feb 25, 2016 8:43 pm Post subject: |
Hi Kremmen,
Have been using your convertor, and I am trying to set it so I only get 1 warning for each camera, without subsequent ones if I am overspeeding. I have the settings as per the screenshot below, however if I go past a camera position too fast I am still getting a second and sometimes a third warning - it drove my wife mad going up the M6!!
Can you let me know if I have got the settings wrong in your programme, or is there a setting on the Garmin I need to change?
Unit is a Nuvi 2569 LMT-D.
Many thanks |
Posted: Fri Feb 26, 2016 5:57 am Post subject: |
Morning
Your setup looks correct for what you want and should just provide one single approach warning.
2 things to check:
1) Have you just got a single .gpi in the devices poi folder?
2) Can you check any of the gpx files and make sure there is only a single entry for each camera and the marker is a #. In plain English something like 'Gatso1234#70'.
Like this example:
If you opt for an overspeed warning then there will be 2 lines for eac h camera, one with a #(Approach) and one with a @(Garmin keeps checking your speed):
Car Average MPG :
Posted: Fri Feb 26, 2016 8:51 am Post subject: |
Thanks, I'll check this evening, although what software can I use to open and view the gpx files in?
Definitely something odd going on, as last night I set approach to 0 and overspeed to 17. Went past two 30mph cameras at 25/26mph and I got 2 warnings for the first, and 1 warning for the second. |
Posted: Fri Feb 26, 2016 9:12 am Post subject: |
Gpx will open in Notepad OK.
If you just run the overspeed setting then you are in the hands of the Garmin AI which may or may not produce a warning, multiple warnings or no warning depending on your speed, acceleration deceleration.
The # should just produce a single warning at the proximity set. The @ is Garmins AI trigger.
My first thought, based on your displayed setting is more than one camera file in the poi folder. _________________ DashCam:
Car Average MPG :
