Pocket GPS World :: View topic - Garmin keeps switching off
Wizzardoz
PostPosted: Sun Feb 21, 2016 4:16 pm    Post subject: Garmin keeps switching off Reply with quote
Have a 2699 which I have now tried to reset to factory settings (erase data). It then gives me a UK screen which I accept. On the next warning screen I press OK and the unit turns off.
Any idea how to solve this please?
PostPosted: Sun Feb 21, 2016 5:52 pm    Post subject: Reply with quote
Only thing I can suggest is do another reset.
PostPosted: Sun Feb 21, 2016 6:00 pm    Post subject: Reply with quote
2699 turning off randomly.
We've had this before:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=96200
Satnav:
Car Average MPG :
Wizzardoz
PostPosted: Sun Feb 21, 2016 7:04 pm    Post subject: Reply with quote
Thanks! After about 8 hard resets, it seems to work now. Not sure if it will happen again but time will tell!
Wizzardoz
PostPosted: Sun Feb 21, 2016 9:27 pm    Post subject: Reply with quote
Actually the problem was self-created. I moved the POI directory and contents to the SD card via PC and removed the POI directory on the Garmin. This is what caused the confusion. When I removed the SD card it worked and I thought it was the hard resets. As soon I put the card in, it stopped again - then I realised that this POI directory was the issue.
BTW, installing camera database from here with manual option on the loader, I do not get a choice where I want to put them. Question
PostPosted: Sun Feb 21, 2016 10:36 pm    Post subject: Reply with quote
Only option you get is to device or computer.
I install mine to computer then manually copy to my nuvi.
Surprised at your cause. I run a POI folder on both my device and card, and I know of many others that do, without any issue.
dales
PostPosted: Sun Feb 21, 2016 10:51 pm    Post subject: Reply with quote
You get the option of Device or Computer.
Select Garmin Device.
The next screen gives a drop-down list, so you can select either Device (nuvi 2699 unit ID nnnn) or Memory Card (drive reference letter).
Dales.
Edited 23.2.16 - sorry I originally put Computer instead of Device, as the option to select to get to the SD card.
dales
PostPosted: Sun Feb 21, 2016 10:58 pm    Post subject: Reply with quote
Yes I run my Poi's quite happily from my SD card.
But note that these must be the Poi's that have been processed by PoiLoader (ie a .gpi file).
I can imagine that the Garmin might choke if you put the raw Poi data (eg .csv or .gpx files) on the SD card.
Dales.
