Newsletter
Pocket GPS World :: View topic - Satmap active 10 won't turn on
birdy69
PostPosted: Tue Jul 28, 2015 3:36 pm    Post subject: Satmap active 10 won't turn on Reply with quote
Hi, I have an active 10, which l bought around a year ago second hand, it's been fantastic, replaced the normal battery cage with the proper Lipoyl rechargeable battery from satmap and all the proper charger and cable too. I'm an avid mtb cyclist and use it all the time so as not to get lost on my travels. So the device is frequently getting charged overnight. On Saturday, the screen started to flash irratically when l plugged it in, and now it won't even turn on. When you press the on button it flashes once and turns off, any ideas????
PostPosted: Tue Jul 28, 2015 3:38 pm    Post subject: Reply with quote
No but satmap have very good customer support, why not call them?
PDK3
PostPosted: Tue Feb 28, 2017 12:12 pm    Post subject: Reply with quote
This happened to me at the weekend, it flashed a white screen and switched off. The problem is track logging is clogging memory and causing a crash. SatMap Active runs on Microsoft Windows Mobile operating system, therefore is susceptible to Microsoft Windows type problems. Memory management is important with the SatMap, be mindful to stop and save/reset Track Logs. If you have problems, as with Windows PCs, first switch it off/on, or plug it in and reset everything!
How to fix white screen flash power on issue:
1) Plug your SatMap into the computer using the USB lead, it should then power on by itself.
2) Main Menu - Settings Button - Default Button - Yes - Clear All
3) Trip Log Screen - Menu - Reset All.
The SatMap is still 500% better than any Garmin, all of which are an absolute dog to use.
Very Happy
PostPosted: Tue Feb 28, 2017 1:52 pm    Post subject: Reply with quote
Really? I tried a satmap once and wouldn't touch one with a barge pole Very Happy
19.012 (12 Jan 22)
Terms & Privacy
