Pocket GPS World :: View topic - Nuvi 3598-D First impressions / Latest firmware (4.80)
Goto page Previous  1, 2, 3 ... 20, 21, 22
PostPosted: Wed Apr 01, 2015 11:51 am    Post subject: Reply with quote
Then I'm not sure what is happening ... may be worth calling Garmin Product Support on their Freephone number 0808 238 0000
@xtraseller Under those circumstances it would still show that the correct cable is connected, here it isn't even doing that.
PostPosted: Wed Apr 01, 2015 11:54 am    Post subject: Reply with quote
Not a 3598 but I've just tested mine.
With no cable connected I get exactly the same as you. Once I connect the cable and the charging symbol shows it has power the 'tick' in the compatible box appears within about 20 seconds.
3 possibilities:
Cable is broken (check pins on cable and device)
Power end is not making connection in car (check unit is charging)
Device has an error
If no signal is being received then the display will show compatible cable connected but the display for subscriptions will never change from 'searching for providers'
Satnav:
Car Average MPG :
R0dG
PostPosted: Wed Apr 01, 2015 12:30 pm    Post subject: Reply with quote
Garmin are now offering me a replacement (not specified whether that will be new) for £19.99 as it is over 12 months old
PostPosted: Wed Apr 01, 2015 12:37 pm    Post subject: Reply with quote
Is it charging when plugged in?
Satnav:
Car Average MPG :
R0dG
PostPosted: Wed Apr 01, 2015 12:46 pm    Post subject: Reply with quote
Update - tried swapping the power lead, now working fine
So it seems the power but not traffic was working on the other lead
Thanks for all your help
PostPosted: Wed Apr 01, 2015 1:12 pm    Post subject: Reply with quote
Both were traffic cables? If so then certainly seems like one was faulty.
R0dG
PostPosted: Wed Apr 01, 2015 1:21 pm    Post subject: Reply with quote
Both traffic leads, yes
PostPosted: Wed Apr 01, 2015 2:02 pm    Post subject: Reply with quote
What you need to watch these days is that some car manufacturers use deep power sockets.
I have 2 car USB plugs. One works one doesn't because even when fully inserted it doesn't reach the bottom.
Also check if the bad lead has a fuse that has blown.
Satnav:
Car Average MPG :
Page 22 of 22
22.051 (01 May 24)
