Kremmen Pocket GPS Verifier
Joined: Mar 03, 2006 Posts: 6652 Location: West London & Reading
Posted: Thu Mar 26, 2015 10:33 am Post subject: SOX and PGPSW File sets |
Here are 2 'helper' images to refer to when we get help requests. As they say, a picture is worth a thousand ..........
1) Where SOX.EXE goes (in the POILoader folder):
2) The 3 files needed (CSV, BMP & WAV) for a successful POILoader upload:
Notes:
a) Ignore the .prev file, that's for CSV Converter
b) Ignore the 50 to fifty filename, that is also for CSV Converter, this example is just to display that all 3 files are needed with identical prefix names.
#kremsearch _________________ Satnav:
M8TJT The Other Tired Old Man
Posted: Thu Mar 26, 2015 1:33 pm Post subject: |
Don't need to now  _________________ Satnav:
Viofo A119 V3 |
vkl Occasional Visitor
Posted: Sun Mar 03, 2019 4:39 pm Post subject: Mercedes Comand Online ntg4.5 |
Hi guys
I have successfully downloaded and installed the .gpx files needed to get the camera warnings and beeps on my system. To do this, I had to create a folder called PersonalPOI and just copy the .gpx files to it. This is working well and all is as it should be.
Now... I would like to expand on this and add the .wav files to get rid of the aforementioned beep. This is where I require some help.
I have downloaded the POILoader exe and installed it. I have downloaded and extracted Sox.exe and copied that to the POILoader directory, as your picture above.
I have downloaded the .wav files that I need by following your step by step guide above but when I run the POILoader software, it generates a POILoader.gpi file which obviously needs to be a .gpx to run in my system.
I'm not quite sure what to do next and am a bit confused about the .bmp, .csv, .wav stage.
Could you point me in the right direction please?
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4399 Location: West Sussex
Posted: Sun Mar 03, 2019 5:06 pm Post subject: |
It's the gpi file you need, and should be placed in the POI folder on your device. This assumes you have a Garmin portable navigation device as per the title of this thread? _________________ Where there's a will ... there's a way. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 743 Location: Knaresborough, North Yorkshire.
