Pocket GPS World :: View topic - Navigate to imported POI broken
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps
spile
PostPosted: Tue Aug 05, 2014 7:08 am    Post subject: Navigate to imported POI broken Reply with quote
I've successfully imported some POIs and these show up fine on the map view. Things go wrong when trying to search for the imported POIs using the Nearby POI function...
Navigate to...
Nearby POI
Existing (built in) categories show correct nearby POs
Group ... Favourite POI (imported categories are shown) ... I am presented with one POI example from one category (I cannot select a category) that is no where near the location set.
Basically searching for a nearby imported POI produces random results that are no where near the actual location.
This used to work fin in version 11 but stopped working in version 13.
Can anyone else confirm or otherwise?
Issue logged with Sygic support and Sygic SDK developer forum
PostPosted: Tue Aug 05, 2014 9:34 am    Post subject: Reply with quote
Why didn't you say all this in your other post HERE on the same subject? You would have saved me idly writing a reply there? Burn In Hell
Incidentally, my Sygic is 14.3.2, which is the latest.
spile
PostPosted: Wed Aug 06, 2014 8:06 am    Post subject: Reply with quote
The link to the SDK forum is:
http://devforum.sygic.com/search.php?search_id=egosearch&sid=dfd584b206e86da06e850c1291e98be5
spile
PostPosted: Sat Aug 09, 2014 7:52 am    Post subject: Reply with quote
Sygic have responded...
Thank you for your feedback, we already know about this issue and are working on the fix. However, this can be only fixed in one of the future updates of the application. I would like to ask for your patience, as it will be solved as fast as possible. Make sure you have automatic updates enabled for our application to receive the update instantly when it is released.
spile
PostPosted: Sat Nov 01, 2014 9:15 am    Post subject: Reply with quote
Update...now fixed in the new version of Sygic.
PostPosted: Sat Nov 01, 2014 9:48 am    Post subject: Reply with quote
OK, so you can navigate to a POI now but how do you set up alert sounds and distances for user POIs to make the importation of a speed camera database a useful feature in the new version?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Sygic McGuider/Mobile Maps All times are GMT + 1 Hour
23.063 (18 Jun 25)
