Pocket GPS World :: View topic - pairing 2210 and co pilot 5 bluetooth
lexuscol
PostPosted: Sat Sep 18, 2004 9:01 pm    Post subject: pairing 2210 and co pilot 5 bluetooth Reply with quote
Hi all, Can anyone assist me , just got co pilot 5 with co pilot gps receiver, box said instructions for setting GPS contained, sods law no instructions within. I am unable to get the 2210 and co pilot to talk to each other instructions on how to do so greatly appreciated.
Co pilot installed and running OK, unable to use it yet due to lack of receiver pairing. Help please someone Sad
Col
AOD
PostPosted: Sat Sep 18, 2004 10:07 pm    Post subject: Reply with quote
Don't worry, the same thing happened to me.
Whoever is putting together the boxes forgot to include the Connection instructions, fortunately it's pretty easy even without these.
1. Go to the Today screen on your PPC.
2. Tap the Bluetooth icon at the bottom left, make sure BT is turned "ON". You should see a blue flashing LED on the front of your PPC.
3. Make sure your BT GPS is switched on and that the blue LED on this is flashing.
4. Via the BT icon again, open the "Bluetooth Manager".
5. Tap the "New" menu and select "Connect!".
6. Make sure "Explore a Bluetooth device" is highlighted and tap "Next"
7. Under the device heading it should say "<No device selected>..."
Tap this to search for your BT GPS. This can take a few seconds, during which the BT logo at the top right will continue to rotate.
8. You should see "BTGPS..." as an available device. Tap the icon when it appears.
9. Tap the Serial Port icon listed in the service selection box. Tap next. NOTE: Make sure you leave the box unchecked where it says, "Use a secure encrypted connection".
10. Once your Pocket PC has established a connection, tap the Finish button.
11 You should see the My Shortcuts screen with your BT receiver listed (it will appear as "BTGPS XXXXXXX:Serial Port" where the X's are letters and numbers). Tap and hold the icon for your receiver and select Connect from the pop-up menu.
12. Close out of Bluetooth manager. Your GPS is now ready to connect to CoPilot.
Launch CoPilot and from the GPS menu on the main toolbar, select Options. Tap the button "Setup GPS". Make sure "Connection setup" is on "Automatic" and tap Next. It should now scan for your GPS. When it finds it, confirm/ok the resulting screen and you're good to go.
That should be it! Let us know how you get on.
lexuscol
PostPosted: Sat Sep 18, 2004 10:22 pm    Post subject: Reply with quote
Thank you, will do. Smile
lexuscol
PostPosted: Sun Sep 19, 2004 8:20 pm    Post subject: Reply with quote
Still haven't managed to pair up the co pilot gps, it doesnt seem to want to play. I borrowed my brothers tom tom gps and it set up ok with 2210.
wont seem to run co pilot though, I get the start up screen of co pilot then the busy icon just hangs on the start pageI have tried soft resetting to no avail. I think im going to throw it away and get something else, i am very fed up. I have had the thing almost a week and have not been able to use it. 300 quid up the spout.
Hunnymonster
PostPosted: Sun Sep 19, 2004 8:41 pm    Post subject: Reply with quote
Before you actually chuck it, post a position from whence it'll be thrown so we can race there and catch it Laughing
Regardless of managing to get CP5 to launch, can you pair the CP GPS unit ? That's your first need. You can verify the pairing is working and the unit is outputting data via GPSInfo, GNSTester or a similar program - we all have our personal favourites on that one.
The inability to launch CP5 may be down to lack of free available memory in your iPaq (I've had the same happen to me - with other programs) and when I've freed up memory it's launched perfectly.
Freeing up memory (in my case) was achieved by uninstalling some stuff I no longer used, moving some rarely used stuff to the memory card and emptying my PocketIE's temporary files - your mileage on this one may vary of course!
lexuscol
PostPosted: Sun Sep 19, 2004 8:51 pm    Post subject: Reply with quote
doesnt seem to be outputting data , when the screen does come up it says no GPSsignal check connection CPGPS is charged up and bluetooth light is blinking
22.053 (15 May 24)
