Pocket GPS World :: View topic - 825 Battery Drain
825 Battery Drain
robbooth
PostPosted: Thu Mar 06, 2014 9:33 am    Post subject: 825 Battery Drain Reply with quote
I have noticed strange behaviour from my 825 regarding battery drain when left disconnected in the glovebox.
If I forget to clear a route, disconnect it and then shove it in the glovebox, nine times out of ten when I next come to use it (usually overnight but could be only a few hours later), the battery will be so flat the only way to get it going is via a reset (holding power switch). The unit is definately turning off, as I thought that I may have been touching the screen during the 10 second shutdown when putting it in its case and cancelling the shutdown, but I have watched and it counts down and the screen goes off. If I clear the route before putting it away it's fine - there's obviously some additional power drain staying active when shutdown with a route in progress. Bluetooth is unused and disabled.
Anybody experienced anything similar?
TT 825 (The companies)
TT 940 (Back in retirement, but still the best)
TT 550 (the wifes)
Garmin CoPilot & Nuvi 200W (now retired)
22.051 (01 May 24)
