if1977 Lifetime Member
Posted: Tue Oct 01, 2013 9:55 pm Post subject: how to install the database to tomtom on iphone |
As above I am now using tomtom on my iphone. is there a link on how to install the cameras to my tomtom. _________________ NEW Tomtom GO 500 (hope it is good)
iphone (running all day, doesn't like it)
XL LIVE IQ Routes (Got stolen and miss it)
GO 510 (in drawer now, time for upgrade) |
Andy_P Pocket GPS Moderator
Posted: Wed Oct 02, 2013 5:14 am Post subject: |
Yup... See the
Installation Guide _________________ "Settling in nicely" ;-) |
sgould Frequent Visitor
Posted: Wed Oct 02, 2013 1:03 pm Post subject: |
I've done this on a couple of iPhones. But the DiskAid software was broken for a while. I haven't checked it with iOS 7 on the iPhone yet. _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
st1967 Lifetime Member
Posted: Mon Oct 07, 2013 11:07 pm Post subject: |
sgould wrote: | I've done this on a couple of iPhones. But the DiskAid software was broken for a while. I haven't checked it with iOS 7 on the iPhone yet. |
Still works fine, you just need the latest version of diskaid now. I think it is something like v5.48
There is a beta for diskaid 6 but the last stable release works with ios7 _________________ Samsung S22 Android, Google Maps & Camera Alert
Having problems allready
I have diskaid and trying to copy the files from my folder on computer to the iphone on disc aid. I have selected the right folder etc. its the same as the installation picture. when I select them and click open to start copying them I get a error message as follows
Error opening destination file, close any other application on your device that may be locking this file.
I have made sure the app is closed by double clicking the home button on iphone, infact I have closed all apps and there is no other programs open on my computer either. ant help guys. pleeessseeeee _________________ NEW Tomtom GO 500 (hope it is good)
Posted: Mon Oct 07, 2013 11:19 pm Post subject: |
if1977 wrote: |
Error opening destination file, close any other application on your device that may be locking this file. |
The instructions are a little old now, not sure if they have been updated since apple locked out the system in IOS6
1. You need to make sure you have the latest version of TomTom for iphone. v1.15.1 is the latest (POIs only worked from 1.14 onwards)
2. You need all the files from the instructions for the camera database for the iphone 4 (pgpsw-iphone-tt-1.7-iphone4)
3. You are trying to copy the files to the wrong directory with diskaid. You have to create a directory called POI in the documents section and that is where you put all the camera files. icons, ogg sounds and OV2s, in fact all custom POIs you want go in here.
4. You will need to copy the mapsettings.cfg file from (pgpsw-iphone-tt-1.7-iphone4) and overwrite your version or else you will not be warned when near, so you will lose any favourites, but if you get an old version of POIEdit you can create a POI category from your mapsettings file before hand if you don't want to lose them.
Once done correctly it quickly becomes second nature but it does work. _________________ Samsung S22 Android, Google Maps & Camera Alert |
Posted: Mon Oct 07, 2013 11:26 pm Post subject: |
where is my mapsettings.cfg folder located on my tt. I cant find it anywhere _________________ NEW Tomtom GO 500 (hope it is good)
Posted: Mon Oct 07, 2013 11:30 pm Post subject: |
if1977 wrote: | where is my mapsettings.cfg folder located on my tt. I cant find it anywhere |
Its ok. I found it. I have now copied the new mapsettings.cfg over and overwrite the oldone. how do you set up the speaking warnings. is it already done or needs setting up..... _________________ NEW Tomtom GO 500 (hope it is good)
Posted: Tue Oct 08, 2013 6:52 am Post subject: |
if1977 wrote: | if1977 wrote: | where is my mapsettings.cfg folder located on my tt. I cant find it anywhere |
Its ok. I found it. I have now copied the new mapsettings.cfg over and overwrite the oldone. how do you set up the speaking warnings. is it already done or needs setting up..... |
You don't they are already in the mapsettings. _________________ Samsung S22 Android, Google Maps & Camera Alert |
Posted: Tue Oct 08, 2013 8:18 am Post subject: |
Thanks. They are all working fine now. Just want to say I have saved a few favourites again and theyare woworking fine with no additional programing. Is this normal now. As it was said I had to use poi edit or similar. _________________ NEW Tomtom GO 500 (hope it is good)
Posted: Tue Oct 08, 2013 12:38 pm Post subject: |
if1977 wrote: | Thanks. They are all working fine now. Just want to say I have saved a few favourites again and theyare woworking fine with no additional programing. Is this normal now. As it was said I had to use poi edit or similar. |
No that is correct they will work fine afterwards its just when you copy in the camera mapsettings it will wipe any you had originally.
The POIedit was only to allow you to create your own POI file from your original favourites if you had a lot. I had about 30 favs when I came to put the cameras on so rather than lose them I now have a POI category called Old Favs which I built myself from my original mapsettings file _________________ Samsung S22 Android, Google Maps & Camera Alert |
Posted: Tue Oct 08, 2013 1:16 pm Post subject: |
Ah right. Now I get it. I only had 5 or 6 and put them back in with the post codes so it didnt uoset me that much. Used it today for the first time and its great. Especially on the m6 wuth the specs cameras. _________________ NEW Tomtom GO 500 (hope it is good)
chromakey Occasional Visitor
Posted: Thu Oct 10, 2013 8:43 pm Post subject: |
Apologies for jumping onto your thread.
I have just changed from my tomtom XL to the iphone app. Using diskaid I have managed to copy the camera database over to the POI folder, I then copied the map settings file to the GB & Ireland map folder after renaming the original file .bac
I can see the icons and my favourites etc., but on my drive home this evening the warnings were not working.
The only directories that I could see, within the app are POI and the MAP folder with the original map settings config file in. There was no document folder as shown in the tutorial.
Any suggestions on how to get the alerts working please. |
bw2020 Pocket GPS Verifier
Joined: Aug 17, 2005 Posts: 121 Location: Tayside, Scotland
Posted: Wed Feb 26, 2014 11:19 pm Post subject: |
Hi I wonder if anyone has a mapsettings.cfg file you could PM me please that has all the UK speedzoned cameras as well as the pmobiles and the Euro speed zoned cameras all set up for TT iPhone? Many thanks in advance.  |
adobbing Lifetime Member
Posted: Sun Oct 12, 2014 12:40 pm Post subject: |
bw2020 wrote: | Hi I wonder if anyone has a mapsettings.cfg file you could PM me please that has all the UK speedzoned cameras as well as the pmobiles and the Euro speed zoned cameras all set up for TT iPhone? Many thanks in advance.  |
PM me your email address if still required, I have a file I have supplied to several other users. |
