themagicmaster Occasional Visitor
Posted: Fri Mar 01, 2013 9:37 pm Post subject: database install nulink 2390 |
help please, new user, just downloaded and installed database to my device, looking in the poi folder it lists 'garmin speed.gpi' is this correct, does garmin's poi loader covert the original csv files/ mp3 files to a single gpi file. Was just trying to check all downloaded correctly. Thanks |
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 491 Location: South Yorkshire
Posted: Sun Mar 03, 2013 11:53 am Post subject: Re: database install nulink 2390 |
themagicmaster wrote: | help please, new user, just downloaded and installed database to my device, looking in the poi folder it lists 'garmin speed.gpi' is this correct, does garmin's poi loader covert the original csv files/ mp3 files to a single gpi file. Was just trying to check all downloaded correctly. Thanks |
When you run POI Loader it will supply the name of the GPX file to use, which you can then change - But yes it will convert all files into a single file for the garmin.
Also the nulink 2390 does not work with MP3 files, you need the WAV files instead.
And remember to download sox from PGSPW (link found in another thread) and save the exe in the poi loader application folder |
Posted: Mon Mar 04, 2013 6:32 pm Post subject: all sorted |
Thanks for the info, downloaded wav file, intalled sox. tested on the road, all appears to work. thank you for your help. |
carl_w Lifetime Member
Posted: Mon Mar 04, 2013 11:20 pm Post subject: |
Sox? What does that do? I've been using POILoader on a Mac with no problems without it. |
Kremmen Pocket GPS Verifier
Posted: Tue Mar 05, 2013 8:14 am Post subject: |
SOX.exe is a third party utility that converts .WAV files into a format that the Garmin via the POILoader can understand.
With SOX you can have spoken warnings, without SOX you just get bongs.
Your choice between something like "Gatso ahead, speed Limit 50 miles per hour" or 'Bong' _________________ Satnav:
Car Average MPG :
Posted: Tue Mar 05, 2013 9:19 pm Post subject: |
Kremmen wrote: | SOX.exe is a third party utility that converts .WAV files into a format that the Garmin via the POILoader can understand.
Your choice between something like "Gatso ahead, speed Limit 50 miles per hour" or 'Bong' |
You sure it's not a Bing |
Posted: Mon May 27, 2013 11:43 pm Post subject: |
Your choice between something like "Gatso ahead, speed Limit 50 miles per hour" or 'Bong' | I just upload the wavs with the speed cam files and it works fine? |
