Pocket GPS World :: View topic - Running CamerAlert in background/standby?
GSDog
PostPosted: Sat Feb 16, 2013 9:20 pm    Post subject: Running CamerAlert in background/standby? Reply with quote
I've set up CamerAlert with the bluetooth in my car and it is excellent.
However, as soon as my iPhone goes into standby mode or if I manually set the iPhone to standby by pressing the off button the app will only give a visual notification on my phone as will not give any audible alerts. This means I need to constantly look at the phone screen in order to see any alerts...
How do I get the app to give me audible alerts whilst the phone is in standby?
The only 'solution' I've found is to put the app into prevent standby mode but this means the screen is on 24/7 and it drains the battery very quickly.
Thanks.
PostPosted: Sat Feb 16, 2013 10:55 pm    Post subject: Re: Running CamerAlert in background/standby? Reply with quote
Had you thought of killing the app when not in use? Can this be done on Apple devices?
PostPosted: Sat Feb 16, 2013 11:28 pm    Post subject: Re: Running CamerAlert in background/standby? Reply with quote
Erm... but then it won't work... :/
Best thing to do, in my opinion, is get a car charger to keep the phone powered when in use.
GSDog
PostPosted: Sat Feb 16, 2013 11:30 pm    Post subject: Re: Running CamerAlert in background/standby? Reply with quote
I'm not sure.
I have read that CamerAlert is able to give audible warnings when in background mode but in my experience that does not happen. As soon as the app is put into the background or my iPhone 4 is put into standby/screen locked I get absolutely no audible warnings, only a tiny blue notification on the screen.
What I'd really like is to be able to get into my car with my phone in my pocket and totally forget about it but still be able to get audible alerts from CamerAlert. It's not really practical for me to have my phone out with the app at the foreground with the screen on all the time.
GSDog
PostPosted: Sat Feb 16, 2013 11:31 pm    Post subject: Re: Running CamerAlert in background/standby? Reply with quote
I have just ordered one funnily enough. Cool
So is it not possible to have the app give audible warnings whilst the phone is in standby?
PostPosted: Sat Feb 16, 2013 11:38 pm    Post subject: Reply with quote
It *does* work when the phone is in standby. However, you mention that you have got it set up to use bluetooth so it may be that your phone's bluetooth (or your bluetooth receiver) is not playing nicely when the phone is in standby.
As an experiment can you go for a drive with the phone in standby BUT not connect to bluetooth? I.e. so you just get the sounds from the phone itself.
This will 1) prove that the app *does* give audio in the background and 2) give us an idea if the issue is with the bluetooth set up.
Regardless of using it in standby or not I'd still recommend using a car charger when using GPS over any considerable distance.
PostPosted: Sat Feb 16, 2013 11:39 pm    Post subject: Re: Running CamerAlert in background/standby? Reply with quote
I know that. I'm not that stupid even if I frequently give that impression. The OP said he had it on 24/7 and I'm fairly certain that he doesn't actually drive for 24 hours every day and I did say 'when not in use' Very Happy
Having defended myself, I think that your solution is probably the best way around the battery discharge problem.
GSDog
PostPosted: Sun Feb 17, 2013 1:20 pm    Post subject: Reply with quote
Ok. I've been out doing some testing this morning.
The app does give me audible alerts in standby mode when the "Audio route" is set to phone. However, once I change the "Audio route" to bluetooth it does not give any audible alerts when in standby mode; only visual.
Like I said above, the audible alerts via bluetooth work fine when the phone is not in standby, so it is definitely something to do with being in standby or in background mode which prevents the audible alerts via bluetooth from working.
Any chance the devs can look into this? If it was working I'd simply be able to forget about the app but as it stands I'd have to plug my phone into the charger and change the settings every time so that it doesn't go into standby. Crying or Very sad
PostPosted: Sun Feb 17, 2013 11:18 pm    Post subject: Reply with quote
How can you get visual notifications when the phone is in standby?
PostPosted: Mon Feb 18, 2013 10:23 am    Post subject: Reply with quote
Local notifications?
PostPosted: Mon Feb 18, 2013 1:08 pm    Post subject: Reply with quote
Interesting use case. I get a feeling that this scenario never occurred in Apple's design sessions (specifically, starting a new BT connection for A2DP while the device is in standby). In fact, the sound through device speaker only works in standby because we benefit from an undisclosed glitch in the OS.
We'll look into our BT options some more, but for now your best solution for now is to get the car charger, and to set CamerAlert to "Prevent standby".
