Pocket GPS World :: View topic - New Nissan COnnect with V1.5 firmware
PiaggioMP3
PostPosted: Fri Feb 15, 2013 9:10 pm    Post subject: New Nissan COnnect with V1.5 firmware Reply with quote
As you know, the speed cameras from Nissan are in the firmware, not the memory card.
I found the attached document from Nissan and it looks like you can upload / modify the speed camera database with Nissan software.
This a bit beyond my capability, but would it be possible to create an update file with NO cameras in, thereby making the Nissan Connect system empty as far as cameras are concerned? Or did I miss the point?
https://mega.co.nz/#!NsMigCrY!LOBhAx6Vqqztha2R1CxqIEijR3cpbuGOgOrSE72rx6Y
Setup_NISSAN_Connect_PC_Tool.exe
https://mega.co.nz/#!lg9EnC4K!aw8_yGbXd7Vgmeq3J0ASekjVNcAKnnBMQqzfxzc2tDc
Jeff
PostPosted: Fri Feb 15, 2013 9:36 pm    Post subject: Re: New Nissan COnnect with V1.5 firmware Reply with quote
Why would you want to do that? Or am I missing the point?
PS can you copy the relevant bit of the manual here. The damn Chrome popup on the site that yuou linked to is peeing me off Crying or Very sad Apart from the fact that it didn't download for me. Now for a virus check.
PiaggioMP3
PostPosted: Fri Feb 15, 2013 10:08 pm    Post subject: Re: New Nissan COnnect with V1.5 firmware Reply with quote
The point is, if you load the PocketGPS cameras you get two warnings, one from PGPS and one from Nissan, with the Nissan ones being out of date so false warnings as well.
The Manual is 18 pages (pdf). The upload site is MEGA and is protected by PGP (pretty good privacy) so that anything on there cannot be seen, this may be causing you an issue. They are virus free files, as I only uploaded them a short time ago. I will try and find other links.
PiaggioMP3
PostPosted: Fri Feb 15, 2013 10:27 pm    Post subject: Reply with quote
Try this link
http://www.navigation.com/Juke_2012/nissan-eu/catalog/en_GB/EUR/
PostPosted: Fri Feb 15, 2013 11:04 pm    Post subject: Re: New Nissan COnnect with V1.5 firmware Reply with quote
My confusion arose because you missed that little bit of info from your first post.
PostPosted: Fri Feb 15, 2013 11:09 pm    Post subject: Reply with quote
Can't you just switch off the TT-supplied camera warnings on the Connect?
You can on all the normal TomTom models.
"Settling in nicely" ;-)
PiaggioMP3
PostPosted: Fri Feb 15, 2013 11:25 pm    Post subject: Re: New Nissan COnnect with V1.5 firmware Reply with quote
Soz, thought it was obvious.
PiaggioMP3
PostPosted: Fri Feb 15, 2013 11:29 pm    Post subject: Reply with quote
Nissan Connect is not TomTom; if you turn off warnings it turms them off for in-built and add-on POI's
Anyway, back to the original thought - a new camera update purchased form Nissan will DELETE French cameras (now against the law in France to have these), so it is entirely possible to delete them all! But then Nissan wouldnt get any update income. Think the only way to fix it is to somehow edit their update file so all cameras are disabled.
PostPosted: Sat Feb 16, 2013 10:15 am    Post subject: Reply with quote
OK Very Happy . Nothing is obvious to me unless it's spelled out letter by letter Crying or Very sad , Do you have a copy of the Nissan cam database offering. If so, can you open it in Notepad or similar to see the format? If so, just try deleting the contents (on a copy of course) and see what happens.
PostPosted: Sat Feb 16, 2013 10:53 am    Post subject: Reply with quote
it's built into the firmware...
PostPosted: Sat Feb 16, 2013 11:38 am    Post subject: Reply with quote
Doh. Repeat to myself 100 times. "I must read posts and try to twig that if it's built into the firmware you can't overwrite it".
Makes you wonder how often they would get updated though, doesn't it.
