Pocket GPS World :: View topic - Tom Tom Start - Camera Database compatible???
jnielow
PostPosted: Fri Jan 25, 2013 7:53 pm    Post subject: Tom Tom Start - Camera Database compatible??? Reply with quote
Hi I have old Tom Tom Start, I am thinking of subscribing will the database be compatible with my device?
Also someone kindly mentioned about a premium set of POI's just wondered what they include?
I need the following
1/speed cameras
2/low bridges
3/weight restrictions
4/width resrictions
Hope anyone can help new to site, will now have time to navigate around it and try to help myself more!, Great Site!!!!!
Jason
PostPosted: Fri Jan 25, 2013 9:22 pm    Post subject: Reply with quote
the camera database is just another set of POIs so if your unit can accept user-POIs you're good to go.
However, IIRC, out of the box, the original Start models had the "Easy menu" (i.e. a reduced menu) which didn't have the "Warn when near POI" functionality you need to get warnings.
I can't remember if that changed with an official software update,so the first thing to do is see if you have a "Manage POIs" sub-menu in the "Change preferences" menu, and if there is a "Warn when near POI" icon in that sub-menu.
If not, you CAN add a custom menu file to the unit to regain some of the missing features.
There's a very long topic about it here:
How to get more menu options on models with 'Easymenu'
You can either write the required menu customisation file yourself (it's just a text list of the required menu items), or hopefully there should be some links in that topic for ready-made ones.
As for the "premium" POIs, you get access to all of those as well if you have subscribed for the Speed Camera database.
"Settling in nicely" ;-)
jnielow
PostPosted: Sat Jan 26, 2013 2:22 pm    Post subject: Reply with quote
jnielow
PostPosted: Sat Jan 26, 2013 3:09 pm    Post subject: ENABLING POI ALERTS ON TOMTOM "START"/"EASE&q Reply with quote
I have been following this link, as I am trying yo enable POI's.
I have created said text document tomtom.mnu and put it into files SdkRegistry, it then says place in the root of gps!. Sorry to sound dim where is this?, do I have the gps connected to pc with home started?
I did place the file straight into where the folders are contained in the directory for licences,tomtom config voices etc is this correct?, or does it go somewhere else/ I tried the instructions for seeing if it had worked no further menu to enable POI's- not sure what I am doing wrong?
Any help welcome
Jason
AliOnHols
PostPosted: Sat Jan 26, 2013 5:23 pm    Post subject: Reply with quote
Yes, that is correct. The Root is the top-most level you can access, i.e. not in any existing folders but directly into the memory (equivalent to what would be the "C" drive on a PC).
Use Windows Explorer to copy the files across, not TomTom Home.
Sorry, I can't help with the other issues you are having.
Garmin Nuvi 2599
SatMap Active 10 & 20.
22.044 (24 Apr 24)
