Pocket GPS World :: View topic - deleted favorites
deleted favorites
kirlee
PostPosted: Sat Aug 04, 2012 7:41 pm    Post subject: deleted favorites Reply with quote
I've deleted all my favorties thinking I was clearing recent selections. Now I was hoping to get them back from my PC, which I save the Garmin folder to each month, but copying back to the nuvi doesn't over write the .gpx file. Have I saved it wrong on my PC by just copying across or doing something wrong copying back. Hopfully someone out there my have an answer
Thanks Chris Sad
PostPosted: Sun Aug 05, 2012 9:17 am    Post subject: Reply with quote
You need to copy current.gpx from your back up but rename it to something else, eg temp.gpx, then place that in the GPX folder on your nuvi.
On boot the nuvi rewites current.gpx from its internal memory, merging into it any other .gpx file it finds. That'll restore your favourites. Then delete temp.gpx Smile
If you simply copy it across as current.gpx it's overwritten with what's in memory, in your case nothing! And if you don't delete temp.gpx afterwards you'll never be able to delete any of the favourites it contains, as they'll be reloaded every time you boot!
kirlee
PostPosted: Sun Aug 05, 2012 11:03 am    Post subject: Reply with quote
I'm off to try this if that works I owe you one as I'm a van driver my working life is in that b***dy nuvi thanks Chris
PostPosted: Sun Aug 05, 2012 12:07 pm    Post subject: Reply with quote
It'll work Smile
kirlee
PostPosted: Sun Aug 05, 2012 1:14 pm    Post subject: Reply with quote
thank you sussamb it worked and I've recovered all of them to that date
thank you thank you thank you
PostPosted: Sun Aug 05, 2012 4:09 pm    Post subject: Reply with quote
Did say it would work Very Happy
Seriously, glad it worked for you.
