Posted: Sat May 19, 2012 2:56 pm Post subject: TT Map Share Corrections "Deleted" On Device
When you correct a map error on your device, eg incorrect road speed, name, missing roundabout, turning directions etc, as usual the device will ask if you would like to share this with the rest of the TT Community, I choose yes, as I always have done.......after all, I also benefit from the corrections they make.
However, since the release of my current map version, whenever I make a correction and agree to"share" this, I have found there is a problem. You subsequently connect to TT Home and your corrections are uploaded, and you assume everything is okay, but it is isn't.
The next time you are driving at a location where you had previously made a map correction on your device, that correction has disappeared!
For example, I have corrected roads speeds, but when driving along that same section of road after uploading the corrections from my device using TT Home, my correction no longer exists!, so I have to "re-enter" the same correction again!
I have found this isn't a one-off mistake, it has happened every-time after the TT Home upload.
I have the both the current Application version and map on my device.
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Sat May 19, 2012 3:04 pm Post subject:
Interesting! I thought I might have just re-entered the wrong speed limit, but now you have mentioned this, I will have another go, and take more notice of what I am doing and what is happening. _________________ Garmin DriveSmart 50 LMT-D
