Pocket GPS World :: View topic - Frozen Map - Southampton
Roy124
PostPosted: Mon Sep 12, 2011 12:52 pm    Post subject: Frozen Map - Southampton Reply with quote
I am using a 7310. On at least 4 occasions when driving in Southampton near the cruise terminals the Navigon map display has locked up.
On the last occasion this month I noticed that the direction window in the bottom corner, navigation data bottom right, and the reality view all worked. It was the main map that had frozen.
The freeze does not occur at the same point. However on the last but one occasion it got me to the Ocean terminal and then locked up. I did a reset and it worked. On the last occasion, leaving the Ocean terminal the display initially worked and then locked up.
This behaviour has occurred using different map versions. It is probably however that the module around Southampton does not change version to version but the failure point does change.
The navigation function is not impaired so it not a question of Satellite masking or jamming.
Could the GPS software be affected by external EMP?
PostPosted: Mon Sep 12, 2011 1:01 pm    Post subject: Reply with quote
When you drive to Southampton are you leaving from the same place? I'm wondering if it is Southampton that's the issue OR the fact that after, say, 20 minutes (or however long it takes you to get to Southampton) the map freezes.
