Pocket GPS World :: View topic - Memory Map/Tom Tom 3/ Bt Gps
gibbom
PostPosted: Tue Aug 10, 2004 7:12 pm    Post subject: Memory Map/Tom Tom 3/ Bt Gps Reply with quote
Hi there,
I know this has been asked many times before but i need help desperately. I have just installed TTN3 and now when i run MM i always get message CANT OPEN COM PORT, it used to work fine on TTN2. Any ideas as i am off to Dartmoor on Wednesday and would really like to use this.
TC
PostPosted: Tue Aug 10, 2004 9:18 pm    Post subject: Reply with quote
You need to uninstall the GPS driver using add/remove programs on your PDA.
Then go to the downloads section on this web site - look to the left of this page you will see 'downloads'. Then download and install TomTom Navigator 2 GPS Driver 2.07.
Now you can go to Dartmoor in GPS heaven
Ipaq 2210
Fortuna Clip-on [Xtrac V2]
Tom Tom Navigator 3
Memory Map
gibbom
PostPosted: Tue Aug 10, 2004 9:50 pm    Post subject: Reply with quote
TC
Thanks for reply.
I have just updated GPS driver to 3.03 as TTN 3 kept locking out. If i go back to 2.07 surely this will prevent TTN3 from working correctly?!!!
TC
PostPosted: Tue Aug 10, 2004 10:46 pm    Post subject: Reply with quote
The GPS driver is more-or-less the same for any version of TomTom. So you should try it. If it doesn't work just re-install 3.03 (which doesn't appear to work anyway) you've nothing to lose.
Ipaq 2210
Tom Tom Navigator 3
Memory Map
misko
PostPosted: Sun Aug 15, 2004 11:30 pm    Post subject: Reply with quote
Easy way:
Just clickt to remove gps driver. Tomtom ask to reset ppc - ok. After that if you look gps driver stil exist and port is not lock.
I have Ipaq 5550, Fortuna clip on, tomtom 303 and mmap 4.21
22.034 (27 Mar 24)
