Pocket GPS World :: View topic - Over Speed warning too accurate!!!!
LittleDuceCoupe
PostPosted: Fri Jan 28, 2011 11:57 pm    Post subject: Over Speed warning too accurate!!!! Reply with quote
I joined the M3 westbound from the J12 M25 slip where there is an average limit of 50 mph, SPECS. I always set my speed limiter to 52 mph as this is a true 50 mph and at first I was delighted that camalert popped-up the over speed warning but on passing the final camera, when back to the national speed limit, the warnings continued all the way down the motorway to my turn off at M3 J6, Basingstoke!
Do I have to go below the warning speed to stop the warnings? On my TomTom I can set a value to give warnings which I always set at 5 mph above any limit.
I am still getting the app failing to close and freezing my Galaxy S until it pops up the "Force Close" option. This does not generate a fault log.
regards,
Dave.
Question
Dave.
SAMSUNG Galaxy S8 - CoPilot Europe and Australia
PostPosted: Sat Jan 29, 2011 1:57 am    Post subject: Reply with quote
It's more likely that the final SPECS camera is not properly marked in our database. Do you know the camera ID?
253
PostPosted: Sat Jan 29, 2011 10:39 am    Post subject: Reply with quote
Hi Lutz,
I make it 29806, shows up as a Spec end.
Bob
PostPosted: Sat Jan 29, 2011 10:51 am    Post subject: Reply with quote
Not being on Android, I hesitated to comment, but for me on iPhone camera 29806 was working correctly as an End camera last time I went through there (turned off the average). I'm positive about that, because I had wondered, so I watched it carefully. Is the problem device specific?
LittleDuceCoupe
PostPosted: Sat Jan 29, 2011 1:02 pm    Post subject: Reply with quote
I will try it again next time I go down that way next week. I am wondering if it is because I am comming from the beta version of cameralert even though I have linked my account and download the latest database every week?
Do you think I should re-download the app?
Dave.
PostPosted: Sun Jan 30, 2011 9:29 am    Post subject: Reply with quote
Seems logical. Your Beta version would probably be not as good as the later developed new release.
exportman
PostPosted: Mon Jan 31, 2011 9:20 pm    Post subject: Reply with quote
a tolerance setting would be welcome. do 51 near a 50 camera and the nags are more frequent than my wife's Laughing
maybe a percentage 5% ? with the visual reminder but no voice nag?
LittleDuceCoupe
PostPosted: Mon Feb 28, 2011 12:39 am    Post subject: All Clear after every SPECS? Reply with quote
Again, I did my trip to Basingstoke today and joining the M3 J2 westbound from J12 southbound M25 as before. Into the average 50MPH SPECS. CAMERALERT started "nagging" as I was doing 52 mph but after the first camera (the one on the slip road) I got an "All Clear" while still in the area. The final camera of the SPECS series was not indicated?
I would like to report that this final camera is still there and claim my lifetime membership please.
Still having problems with the app "hanging" my Galaxy S and having to Force Close.
Dave.
LittleDuceCoupe
PostPosted: Mon Feb 28, 2011 11:50 pm    Post subject: Reply with quote
Ooops, I meant I was northbound coming from J11 to J12 clockwise M25 to the M3 westbound.
Sorry.
Dave.
PostPosted: Tue Mar 01, 2011 12:07 am    Post subject: Reply with quote
The final camera was there two weeks ago and it's permanent and it's in our database. You don't get "warned" of the final camera, merely get an All Clear (logical, you don't need to be warned that it is there, because it's the end). So the slip road camera warns, then half a mile later, the end camera triggers the All Clear.
(Unless Android version of CamerAlert is different from iPhone version).
PostPosted: Tue Mar 01, 2011 12:36 am    Post subject: Reply with quote
exportman wrote:
how about: if you are over the speed limit for more than a few seconds then it sounds an alert? if you go over but slow down straight away then there'll be no warning that way.
LittleDuceCoupe
PostPosted: Sat Mar 05, 2011 2:59 pm    Post subject: Reply with quote
I got "All Clear" after the first camera and nothing after the last one.
Dave.
PostPosted: Sat Mar 05, 2011 4:42 pm    Post subject: Reply with quote
Here's a theory to run past you. There's a mobile in your line of fire as you go on that slip road, which might well warn falsely, and which would then give an all clear when your line of direction changed to take it out of your arc of entrapment. Just a thought?
LittleDuceCoupe
PostPosted: Sun Mar 06, 2011 6:01 pm    Post subject: Reply with quote
That is very interesting and well thought-out, and quite possible.
Would the false "All Clear" then cancel-out the fact that I was still in an avarage speed zone?
Dave.
PostPosted: Sun Mar 06, 2011 6:28 pm    Post subject: Reply with quote
No it wouldn't (shouldn't). It would just explain the All Clear as you join the M3 though. I know I got an All Clear correctly from the average camera further on.
