Pocket GPS World :: View topic - PrymeNav bugs?
PrymeNav bugs?
mad_bob
PostPosted: Wed Aug 04, 2004 11:28 pm    Post subject: PrymeNav bugs? Reply with quote
I have just installed PrymeNav on an HP 2210 used with a Fortuna Clip on and have had the following problems during a weekend in France:
It does not start reliably – Often it starts with the warning screen and then nothing happens, you have to click on the icon several times before it will run!
It looses the blue tooth connection with the Clip On this happens in both ST and XT modes ( I set the GPS up with the auto setup option)!
PrymeNav will not close down properly and starts up every time you switch on the pocket PC. If you kill it using itask the hardware keys on the pocket PC stop working! The only way to resolve this is with a soft reboot.
PrymeNav locks up while running sometimes the other applications on the 2210 will run fine, at other times the whole machine locks up!
You frequently get the message saying drive to the current route when it first starts even when you are on a major road which if you recalculate the route is subsequently included!
The voice prompt has been at odds with the correct route and the displayed route i.e. turn left at a junction when the route goes right and take the fifth exit from a round about when the route takes the fourth!
The screen refuses to pan at scales greater than 40k on the scale indicator (other functions work but slowly)!
I have used the 2210 & the clip on with Memory Map without a single hitch. Just in case an installed application was causing a problem I backed up and reset the 2210 so PrymeNav was the only application installed. I would be very interested to know if anyone else has had similar issues?
