Pocket GPS World :: View topic - TomTom Announce new x50 Range (550, 750, 950)
Goto page Previous  1, 2, 3, 4
benmaxwell
PostPosted: Fri Jul 09, 2010 6:41 pm    Post subject: Reply with quote
Great. Maybe it is simpler than the threads seem to suggest. I had been pointed to the discussion on
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=83670.
But perhaps (please God!) it'll be easier than I thought after reading that to get the maps to install onto the memory card. Is that right?
Anita
PostPosted: Fri Jul 09, 2010 7:29 pm    Post subject: Reply with quote
If you're going to use a card for the map it's always safer to insert it in a card reader rather than the device when you connect to Home. At one time, even if you selected the card for the updated map, Home installed it both on the card and the internal memory.
But the procedure isn't exactly complicated. You will, of course, be creating a back up of the device on your computer before updating the map. All you need to do is copy that back up to the card via a card reader, so you have both the current map and the application on the card. Make sure the device is disconnected so there's no confusion and then start Home. Home will see the card as a TT device and update the map in the normal way.
Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
benmaxwell
PostPosted: Sat Jul 10, 2010 4:54 pm    Post subject: Reply with quote
I fitted the microSd card, and the maps downloaded onto it. I didn't use the crd separately (though I did ,make a backup!). I'm not entirely sure what is on the internal memory and what is on the card - but it just worked! No specialist knowledge needed. For info I didn't manage to get one that stated its category or speed, but a 4GB SDHC one from Staples @ £12. It seems to work fast.
So it seems the Go 750 Live may be OK. If you buy an expansion card. Thank goodness and thanks to helpers at PGPSW.
Ben
Page 4 of 4
22.052 (08 May 24)
