Pocket GPS World :: View topic - Sound level and motorcycle use
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group
1100guzzi
PostPosted: Sat Apr 03, 2010 5:51 pm    Post subject: Sound level and motorcycle use Reply with quote
I have Telmap 5 running nicely on my Blackberry 8900 and have used it for a couple of local trips in the car just to get the feel of it.
I am very impressed with the facilities, it seems a little slow at route recalculation, but I can live with that.
My biggest problem is that most of it's use will be on the motorcycle (audio only). This is how I used to use Amaze before it imploded.
The sound level is just too quiet, just about acceptable in the car but useless on the bike.
Are there any simple solutions like external amps ?
SyBorg
PostPosted: Sat Apr 03, 2010 7:57 pm    Post subject: Reply with quote
Do you listen to it through the BB headset on the bike? No idea if that's how it works but if so you could get noise cancelling/boosting headset.
TUGAdmin
PostPosted: Sun Apr 04, 2010 12:47 am    Post subject: Reply with quote
Hello 1100guzzi, SyBorg,
There is no way to adjust it from within the application.
Please try to make sure it is set to the maximum before starting up.
As SyBorg asked - are you using a headset? Please make sure that the headset volume is also set to maximum.
Best regards,
TUG admin
1100guzzi
PostPosted: Sun Apr 04, 2010 9:20 am    Post subject: Reply with quote
Thanks for your responses, I didn't mention that I have a helmet mounted speaker system that has a 3.5mm jack and has always worked in the past.
I also play MP3's via this from the Blackberry and the volume has always been sufficient.
SyBorg
PostPosted: Mon Apr 05, 2010 7:13 am    Post subject: Reply with quote
And I guess if you boosted the volume you could end up exploding your ears when you switched back to listening mp3's
mikekay
PostPosted: Mon Apr 12, 2010 4:06 pm    Post subject: Reply with quote
I always use the side volume keys and they seem to work fine for decreasing and increasing volume.
Mike k
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Telmap User Group All times are GMT + 1 Hour
