Talkingbollox Frequent Visitor
Joined: 14/10/2002 15:11:34 Posts: 439 Location: United Kingdom
Posted: Sat Jul 17, 2004 12:46 pm Post subject: Is the v1.96 locked to Navman receivers? |
I have SmartST Professional v1.96. However, I can't use my Road Angel with it (COM1, NMEA 4800) as a GPS receiver.
Is this because the software's locked to Navman receivers? |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Sat Jul 17, 2004 3:38 pm Post subject: |
My understanding is that V1.9x is locked to Navman receivers, V2.x is 'open'. _________________ Tim |
Dave Frequent Visitor
Posted: Sat Jul 17, 2004 3:42 pm Post subject: |
If you purchased SmartST Pro bundled with a sleeve, then it will be locked. If you purchased it with the Bluetooth GPS, then it will be unlocked. |
Posted: Sat Jul 17, 2004 6:27 pm Post subject: |
Dave wrote: | If you purchased SmartST Pro bundled with a sleeve, then it will be locked. If you purchased it with the Bluetooth GPS, then it will be unlocked. |
Really, Dave? Mine was packaged with the Navman bluetooth receiver, but won't work with a serial connection. Can you help explain the deviation please?
BTW I managed to get TT3 and SmartST going at time same time today, with a serial connection on TT and bluetooth on Navman. |
Posted: Sat Jul 17, 2004 6:52 pm Post subject: |
Providing you can go into the GPS Setup screen in SmartST Pro and you are able to turn it off, and select a COM port, then you have the unlocked version. What you may find is that when you have TomTom installed, it installed the TomTom ~ GPS driver which is a COM port fudger. This may be re-mapping COM ports and causing a problem with SmartST Pro and other programs on the PPC. I know it has with me on nearly all applications and I have to uninstall the TomTom ~ GPS driver. TomTom will still work fine, but it's just patch on Bluetooth to stop the hanging when powering down the PPC. Darren says the new version of TomTom GPS Driver doesn't install the TomTom ~ GPS but I'm currently heavily into reviewing another program so haven't had the time to test it yet.
And for anyone interested, a mammoth review will be out next week |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Sat Jul 17, 2004 6:53 pm Post subject: |
The Navman bluetooth GPS will work with TTN3 by setting the Gps to:NMEA 0183v2 and Bluetooth Serial Port Com8. It seems to be the best setting ! |
Posted: Sat Jul 17, 2004 6:56 pm Post subject: |
The Navman bluetooth GPS will work with TTN3 by setting the Gps to:NMEA 0183v2 and Bluetooth Serial Port Com8. It seems to be the best setting ! But is there a better one |
Posted: Sun Jul 18, 2004 9:14 pm Post subject: |
Dave wrote: | Providing you can go into the GPS Setup screen in SmartST Pro and you are able to turn it off, and select a COM port, then you have the unlocked version. What you may find is that when you have TomTom installed, it installed the TomTom ~ GPS driver which is a COM port fudger. This may be re-mapping COM ports and causing a problem with SmartST Pro and other programs on the PPC. I know it has with me on nearly all applications and I have to uninstall the TomTom ~ GPS driver. TomTom will still work fine, but it's just patch on Bluetooth to stop the hanging when powering down the PPC. Darren says the new version of TomTom GPS Driver doesn't install the TomTom ~ GPS but I'm currently heavily into reviewing another program so haven't had the time to test it yet. |
I can change port settings, and turn the port on and off. Will uninstall TomTom ~ GPS and see what happens. |
Posted: Sun Jul 18, 2004 9:39 pm Post subject: |
Dave, I uninstalled TT ~ GPS.
TT couldn't run because of missing component. Same with TT GPS application.
SmartST still couldn't see COM1 NMEA 4800 GPS data.
Any other ideas please, Dave?
Ta |
Posted: Tue Jul 20, 2004 9:43 pm Post subject: |
Try running WinFast Navigator and seeing if you can connect. It's possible that your COM port has been mapped, so try other COM ports in WinFast Navigator.
Usually uninstalling TomTom ~ GPS and soft resetting as it asks you to will still allow you to run TomTom and the GPS applet, just make sure you don't uninstall TomTom GPS (no tilda).
For WinFast instructions/download, try this
http://www.pocketgpsworld.com/winfastnavigatorppc.php |
Posted: Tue Jul 20, 2004 11:05 pm Post subject: |
I've done everything you've suggested. I have even reverted back to TT GPS 2.07.
Winfast Navigator sees COM1 as expected, as does TT3. No such luck with SmartST though.
Any other ideas?
Cheers |
Posted: Wed Jul 21, 2004 8:07 am Post subject: |
That's really weird, so you can connect under WinFast Navigator and get a 3D Lock ? |
Posted: Wed Jul 21, 2004 6:33 pm Post subject: |
Yes, Road Angel connects to WinFast Navigator and get "development" messages.
Although I can change ports and NMEA in GPS setup in SmartST, it cannot receive GPS data from COM1.
Bluetooth on COM8 works ok.
Will try my Emtac jacket and see what happens. |
Posted: Fri Jul 23, 2004 6:42 pm Post subject: |
Well, the plot thickens.
I tried my Emtac Jacket with SmartST and it worked beautifully on COM5, NMEA 4800.
So why I can't get the Road Angel to work on serial port COM1 on SmartST?
I've sent an email to Navman support to see if they can throw any light on it. |
Posted: Sat Jul 24, 2004 11:18 am Post subject: |
It's possible that they're checking for GPGSA and GPGSV before they allow for a fix, but the Road Angel won't support both. It really shouldn't be a problem with most software, but Navman's does seem to be a little more temperamental than most. |
