M8TJT The Other Tired Old Man
Posted: Thu Aug 27, 2009 7:49 am Post subject: |
basile wrote: | linknet wrote: |
I'm afraid not.
linknet |
How come? |
I muck around with IGO skins a bit and I suspect that the reason is that there is a hell of a lot of work involved in changing resolution, and I suspect pretty much impossible to do unless you have a device with the new resolution to test your work on 'as you go' (especially if you have little personal interest in developing the new res) |
Barma_lej Occasional Visitor
Posted: Thu Sep 24, 2009 12:16 pm Post subject: |
linknet,
Will the new Ultra Skin version for iGO 8.3.4.102680? |
naviman Occasional Visitor
Posted: Fri Oct 16, 2009 12:41 am Post subject: |
Hi linknet,
i think i found the last missing german translation.
Please add this to the german 'Dictionary.lang':
Quote: | Road name="Strassenname" |
Regards and thanks again.
TheGrumbler Occasional Visitor
Posted: Wed Oct 21, 2009 2:32 pm Post subject: |
naviman wrote: | Hi linknet,
Hi naviman,
Even after the last change of the German spelling rules the correct spellling is still
"Straßenname"
Regards
TheGrumbler |
Posted: Wed Oct 21, 2009 2:59 pm Post subject: |
I was thinking about this. Actually not every german speaking country uses
'ß'. Look at Switzerland. And i was concerned if every unit can show the 'ß'.
But after finding 147 'ß' in the dictionary, it should be 'Straßenname'.
Please linknet, change the line to:
Quote: | Road name="Straßenname" |
Thanks! |
simon3441 Occasional Visitor
Posted: Thu Oct 22, 2009 3:57 pm Post subject: |
Hello Linknet,
Excellent skin, only just started using Igo8 instead of Tomtom software and found your skin made it usable for me.
Just one thing, any chance of adding a seperate volume control for warning sounds, i.e. speeding or speed cameras?
I never use the voice guidance, which causes a problem when turning the voice volume to zero, i no longer get warning sounds either.
Just a thought.
Cheers. |
Posted: Fri Oct 23, 2009 12:14 pm Post subject: |
Hello linknet,
is it possible to increase the size of the street name signs? They are very small on my VGA display.
Best regards
TheGrumbler |
amirdt Occasional Visitor
Posted: Sun Nov 01, 2009 7:52 pm Post subject: |
First thanks for the great skin, I use it for a long time now.
Will you add support for HTC HD2? (resolution 480 x 800)
Thanks |
kostaschrys Occasional Visitor
Posted: Mon Nov 02, 2009 7:27 am Post subject: color night filter |
Hi Linknet,
I used your skin in my old device, but my new one has a resolution of 234*480 so i cannot use it. Is it possible to apply the color night filter to default skin? The screen I have does not have dimming operation.
Thanks |
opernsys Occasional Visitor
Posted: Thu Nov 26, 2009 12:48 pm Post subject: Thanks! |
I'm running 8.3.2.73871
What ever happened to BTonOff.exe support?
Put the exe in the iGO dir on the SD Card as well as Program Files\iGO
I'm a old user of 8.0 with an older version on Ultra Skin, but now upgrading to 8.3.2.73871 with Ultra Skin 6.0.22, it does not work.
There is no icon in the quick launch.
Is this feature still a feature?
opernsys |
linknet Frequent Visitor
Posted: Thu Nov 26, 2009 1:45 pm Post subject: |
simon3441 wrote: | Hello Linknet,
Just a thought.
Cheers. |
This isn't possible but a workaround is to use "silent voice". Search for it in the iGO forums and you should find a detailed method.
linknet |
Posted: Thu Nov 26, 2009 1:48 pm Post subject: |
TheGrumbler wrote: | Hello linknet,
Best regards
TheGrumbler |
I think it might be possible but it would be a sys.txt entry and not something that can be altered from within a skin.
linknet |
Posted: Thu Nov 26, 2009 1:49 pm Post subject: |
amirdt wrote: | First thanks for the great skin, I use it for a long time now.
Thanks |
Sorry, but only listed resolutions are supported.
linknet |
Posted: Thu Nov 26, 2009 1:51 pm Post subject: Re: color night filter |
kostaschrys wrote: | Hi Linknet,
Thanks |
Yes, but you'd have to include the modification yourself.
linknet |
Posted: Thu Nov 26, 2009 1:53 pm Post subject: Re: Thanks! |
opernsys wrote: | I'm running 8.3.2.73871
opernsys |
Sorry, but not a feature any more, it was dropped for version 6.x.x.
linknet |
