graeme_symington Occasional Visitor
Posted: Fri Oct 02, 2009 6:02 pm Post subject: #40 Live Services Wont Connect |
Drove into Dartford Tunnel with full live servies came out the other side iwth no connection to server. That was wednesday and had no connection since. Anyone got any ideas.
Recovered from a backup to see if that had any effect but didnt. Have also noticed that the light on top, by the on off switch, no longer changes to green, it always orange.
Think i know what your all gonna say but all ask none the less. |
Posted: Fri Oct 02, 2009 6:05 pm Post subject: |
Have you tred resetting it yet? depress the power on/off button until the device re-boots then see what it does - Mike |
Posted: Fri Oct 02, 2009 6:11 pm Post subject: |
Mike
Have to do that as standard about ten times a day anyway, as it locks up every time it sees another car.
OK ok slightly over the top but im sure you know where im comming from. |
Posted: Fri Oct 02, 2009 6:16 pm Post subject: |
Next then is the restore factory defaults from the menu, format the device and re-install your backup, if you don't have a backup created using Windows Explorer you should make one now before you do anything else - Mike |
Posted: Fri Oct 02, 2009 6:22 pm Post subject: |
I do have backups made from windows rather than HOME. Just to get this right before i try. I do as follows
1. Restore factory defaults from the menu on device.
2. format the devices drive. ie delete everything.
3. copy contents of backup onto device.
Just want to check but doing this wont stop it booting will it. |
Posted: Fri Oct 02, 2009 6:25 pm Post subject: |
The steps you describe seem fine to me and once complete it will boot up - Just to make sure you don't delete everything on the device, you need to right click the drive letter associated with the TomTom and select Format, don't choose the Quick Format option - Mike |
Posted: Fri Oct 02, 2009 6:26 pm Post subject: |
Will let you know. Cheers |
Posted: Fri Oct 02, 2009 7:18 pm Post subject: |
No change. Done updates and everything. Just have the permenant orange triangle and says unable to connect to server. |
Posted: Fri Oct 02, 2009 7:35 pm Post subject: |
Just been digging around in the menus and found a network tab where it shows info for "tom tom live connection status"
has fields for
Status: Not Connected
MCC/MNC:
SIM ID:
IMEI:
Model:
All the other fields are blank.
Would have thought at least sim should have an ID. Have removed and re inserted it but no change |
Posted: Fri Oct 02, 2009 8:39 pm Post subject: |
That looks like the Sim card or the GPRS modem in the unit has died, give TomTom Support a ring on Monday morning to discuss a repair/ replacement on 0845 161 0009 - Mike |
Posted: Fri Oct 02, 2009 8:46 pm Post subject: |
Thanks for trying anyway Mike. Cheers |
