Pocket GPS World :: View topic - Nuvi 200 wav files with latest poi loader
Hairybathplug
PostPosted: Tue Aug 04, 2009 11:36 pm    Post subject: Nuvi 200 wav files with latest poi loader Reply with quote
Can someone tell me if the latest POI Loader supports wav? I see from a forum search that an early beta version supported it but some of the later versions did not. Links to the old working beta version are now defunct. I have a full set of correctly named wav files in my camera database folder but when loaded I just get the 'Bong'. I tried shoving 'sox' into the loader but still no sound. Any ideas? or do I need the old beta version?
Hairybathplug
PostPosted: Wed Aug 05, 2009 9:50 am    Post subject: Reply with quote
I'm still not having any luck with this, does anyone know of a live link to poi loader v 2.4.0.0 beta?
BigPerk
PostPosted: Wed Aug 05, 2009 10:09 am    Post subject: Reply with quote
I've tried the links given in
Beta version of POI loader (Garmin)
and they have all been either changed or broken (presumably by Garmin). Whether there are any good links in other threads or whether you can find any help there I don't know. Try a search (using 'ALL') for poiloder garmin beta wav or combinations to find the relevant threads.
Possibly some one has made a copy of what you want and may be able to help you - watch this space Wink
(Navigon 70 Live, Nuvi 360)
Hairybathplug
PostPosted: Wed Aug 05, 2009 10:24 am    Post subject: Reply with quote
Thanks for the reply BigPerk, I've found a few links here on the forum but all defunct, a quick search on google shows lots of references to it but again all links are defunct. I thought the latest loader (no longer beta) surely would support wav but I guess not.
Hairybathplug
PostPosted: Wed Aug 05, 2009 1:39 pm    Post subject: Reply with quote
FIXED! Beta 2.4.0.0 and all is well
dales
PostPosted: Wed Aug 05, 2009 5:43 pm    Post subject: Reply with quote
Odd.
POI Loader 2.5.3 works fine with the .wav files for my nuvi 255WT, every week!
Dales.
Hairybathplug
PostPosted: Wed Aug 05, 2009 9:17 pm    Post subject: Reply with quote
Hi Dales, Its loader version 2.5.2 that I had a problem with ( thought it was the latest) , I've now downloaded 2.5.3 but still the same theres just no sound. If I load exactly the same files with the old beta loader everything is ok. Maybe its just an issue with my old nuvi 200, software is right up to date using web updater but hardware wise it is of course still an old unit. Interestingly the loaded file size is about 100kb smaller with the beta loader than 2.5.3 . Anyway I have voice warnings now so I'm happy. Cheers & Beers, HairyBP
Gardela
PostPosted: Mon Aug 10, 2009 1:06 pm    Post subject: Reply with quote
Yo. I had a similar problem. The following steps solved all issues:
1. Convert mp3 to wav and place them in the folder with PGSW database.
2. Install SOX 14.0.1, *not* the newest version, in the same folder as POILoader.
3. Run POIloader.
4. Follow instructions.
It looks like the latest version of SOX was causing problems in my case. I have the latest version POLloader.
riccole
PostPosted: Sun Aug 30, 2009 10:44 pm    Post subject: voice alerts on Nuvi 255W Reply with quote
Hi I have subscribed to pgps for speed cameras which I have down loaded for UK and Europe onto sd card, and they seem to work fine.
My unit is 255W can some one explain (step by step please) how I can down load and use the voice alerts rather than just the bong sound
Rick
dales
PostPosted: Mon Aug 31, 2009 5:07 pm    Post subject: Reply with quote
Downloads and instructions are here.
Dales.
riccole
PostPosted: Mon Aug 31, 2009 8:36 pm    Post subject: Reply with quote
Thanks Dales loaded camera manager, also downloaded voice and converted them from mp3 to wav files using nero .
will try uploading them to my Garmin Nuvi 255W later,
Can you tell me if the voices can be used on the european speed cameras?
Rick
PaulB2005
PostPosted: Tue Sep 01, 2009 8:08 am    Post subject: Reply with quote
If you download the European (KPH) voices then yes...
22.051 (01 May 24)
