Newsletter
Pocket GPS World :: View topic - New Safety Camera Icon Sets Available - 44x44 Pixel Options
Goto page Previous  1, 2, 3 ... 11, 12, 13, 14  Next
beeney
PostPosted: Tue Aug 18, 2009 4:02 pm    Post subject: speed camera icons and voice camera alerts Reply with quote
hi could u tell me if these will work on a navman icn 520 pls
GerryC
PostPosted: Tue Aug 18, 2009 4:12 pm    Post subject: Reply with quote
Hi beeney, welcome to the forum.
By all means give it a go. On the previous page, it's noted that the 24x24 icons work on a Navman device - don't know if it would work on yours though.
You may also want to check out the Navman forum where I've just seen info regarding using wav files (see the Navman download instructions).
Gerry
TomTom730T
Cameralert for Android
Brodit ProClip mount
PostPosted: Tue Aug 18, 2009 5:20 pm    Post subject: Reply with quote
Don't forget that Navman use 8 Bit colour depth so loading the alternate sets which are 24 Bit might not work unless you alter this prior to installing - Mike
PostPosted: Sun Dec 13, 2009 8:33 pm    Post subject: Re: icons Reply with quote
browny99 wrote:
hi guys, Newbie here!!! i think i have read all this forum on changing the icons, but i cant seem to find a page that tells me a step by step guide to install them on my new go 750.
The installation is the same for all TomTom's but it does require you use our speed camera database.
maybe im asking to much since i used to own a snooper syrius, which is the best for speed cameras
<cough> I'll beg to differ there, OUR database is superior to Snooper's. They may have a decent device but our data is better.
So i need help on how to put yr icons on my 750, also want to check out the sound but, we can do that another dayall help appreciated, thanx.
As per the icons, our real voice alerts are also available but again will require that you use our speedcam database service.
Darren Griffin - Editor
PostPosted: Sun Dec 13, 2009 9:20 pm    Post subject: Reply with quote
Keep your eyes peeled for the mobile speed camera locations then as the TomTom offering is fairly pathetic in this area, the database from this site will notify you of locations known to be frequented by the mobile cameras. I consider a warning of such a location far better even if there is nothing there at the time you pass - with the TT you are lucky to see anything at all to do with mobile locations - drive carefully for the next three months is my advice - Mike
PostPosted: Sun Dec 13, 2009 9:40 pm    Post subject: Re: icons Reply with quote
browny99 wrote:
so i cant install the icons alone, unless i pay for the database?
You can install the icons we offer but they are designed for our database and as TomTom don't permit the icons for their database to be changed, installing the ones we supply would be pointless.
PostPosted: Mon Dec 14, 2009 6:31 pm    Post subject: Reply with quote
Your TomTom will have been supplied with Navcore 9 software installed but it won't alter the speed camera warnings.
If you change to the offering from this site you can use the spoken voice alerts so approaching a camera the device will say something like "Warning Gatso ahead, speed limit 30 miles per hour" so it tells you the type of camera and the rated speed prior to you getting a pre set distance from the camera - Some of the voice warnings even have siren sounds followed by the spoken alert - Mike
Barncluith
PostPosted: Fri Jan 08, 2010 7:46 pm    Post subject: Reply with quote
The 44x an 48x don't work on the Garmin Nuvi 205W Sad
PostPosted: Fri Jan 08, 2010 7:59 pm    Post subject: Reply with quote
There is a table of applicability near the top of the extra icon downloads page which explains which models support the use of these icon, AFAIK Garmin don't support any of the larger format icons on any device - Mike
transplant
PostPosted: Sun May 09, 2010 8:14 am    Post subject: Garmin nuvi 255WT Reply with quote
Hi guys,
Just uploaded the 24x24 speed rated icons to the Garmin nuvi 255WT - works perfectly so you can update your database on this one. (Currently running software version 6.40 and audio version 2.30 with map CN Europe NT 2010.30)
Cheers (Great website by the way!)
TheQuest
PostPosted: Sat Aug 21, 2010 1:49 am    Post subject: Where do I put........... Reply with quote
Hi all
Could someone please help me with where to put GerryC's Safety Camera Icons on my Garmin nuvi 1490T please? Embarassed
I have downloaded the Speed Camera Database and Voice files [mp3 to wav] and loaded to a SD Card with POI Loader, drive tested and it worked it's magic. Very Happy
Now I would like to install GerryC's Safety Camera Icons, but do not know where they go, because it says to put them in the map folded which I have no idea where it is on my device.
Thank in advance for any replies.
Take Care
TheQuest Cool
When Nothing is Certain, Anything is Possible.
PaulB2005
PostPosted: Sat Aug 21, 2010 10:29 am    Post subject: Reply with quote
With the Garmins you have to replace the icons from the speed camera download before uploading them to the unit with POILoader. You don't move or copy anything to the unit yourself.
Just unzip the speed camera download and then copy the new icons over the original ones. Then upload with POILoader.
TheQuest
PostPosted: Sat Aug 21, 2010 9:26 pm    Post subject: Reply with quote
Hi PaulB2005
Thank you very much for you reply. Very Happy
Will do as you explained now, and give the 1490T a simulated test run.
With many regards
Take Care
TheQuest Cool
PS: Just to update PaulB2005, that it worked as said, many thanks once again. Thumbs Up
maa1506
PostPosted: Sun Jul 29, 2012 7:30 am    Post subject: Primo? Reply with quote
Is there a custom camera icon for Igo Primo at all please and where does it need to be installed?
PostPosted: Sun Jul 29, 2012 9:49 am    Post subject: Reply with quote
It ain't that easy. The camera icons are in the data.zip/gfx folder and are in the file speedwarn.bmp. They are in a special iGO .bmp format for which you need an iGO decompressor. The icons are not single icons, but are in a strip of all warnings and the speedwarn.spr file tells iGO how to process these icons. Alternative speedwarn icons can be obtained from several places on the web if you google for them. Good luck!
Page 12 of 14
20.083 (17 Aug 22)
Terms & Privacy
