Pocket GPS World :: View topic - Satmap wont switch on ?
Mike777
PostPosted: Sun Aug 09, 2009 6:45 am    Post subject: Satmap wont switch on ? Reply with quote
Hi all
I have just discharged my batteries in the satmap (down to one red bar)
I then connected to charge the power pack and nothing ! I have replaced with normal batteries and the unit just will not switch on.
Really confused on this...........any ideas or resets ?
Many thanks for your time
Mike
LostMike
PostPosted: Sun Aug 09, 2009 10:07 am    Post subject: Reply with quote
Sounds odd but I had something similar once when one of the "new" batteries was slightly low on power. A good set of new batteries and all was well.
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
Bosun
PostPosted: Sun Aug 09, 2009 10:24 am    Post subject: Reply with quote
Mike,
I had the same problem a while ago but using the Li-Pol battery.The unit was as dead as a doornail.
Sent it back to Satmap who replaced the battery and all was well.I don't think from your post you are using the Li-Pol but it could be battery related in some way.
Ian
Bosun
PostPosted: Sun Aug 09, 2009 10:26 am    Post subject: Reply with quote
Sorry,from re reading your post you are using the Li-Pol.
I would suggest then a call to Satmap for a replacement.
Ian
terry8
PostPosted: Sun Aug 09, 2009 2:40 pm    Post subject: Reply with quote
I Have just returned from a six day walk along the Dales Way. Unit worked fine for five days through some pretty inclement weather, but when trying to boot up unit for last day after charging it up it went completely dead, this despite having tried both Li-Pol and Lithium batteries, so reading above comments was of great interest. My initial thoughts were that it had been the rain that had caused the problem, but on reading forum I am now wondering. Satmap have asked me to return unit.
BigPerk
PostPosted: Sun Aug 09, 2009 3:18 pm    Post subject: Reply with quote
Or might it be the charger at fault?
(Navigon 70 Live, Nuvi 360)
Mike777
PostPosted: Sun Aug 09, 2009 4:55 pm    Post subject: Reply with quote
Thanks for all the replies.........
I am using the Li-Pol battery pack. However this has just been one of quite a few problems with the Active 10. Ie Data being loss, setting disappearing, taking a long time to lock on, won't work !
So I contacted Amazon today who offerred to give a refund (unit purchased in Feb 09) I have since purchased a new one today from another retailers and so far it appears to be much better than my old one, mainly locks on in seconds rather than minutes.
So I think maybe my old unit was a bit poorly, but I am happy.
Thanks again
Mike
terry8
PostPosted: Mon Aug 10, 2009 3:38 pm    Post subject: Reply with quote
As I said in my post I used both Li-Pol and brand new Lithium batteries in the original carriage both to no avail. So this should have ruled out the charger
BigPerk
PostPosted: Mon Aug 10, 2009 5:36 pm    Post subject: Reply with quote
It was admittedly a longish shot - just seemed possible that if the Li-Pol was being charged while still connected to the Active10 (I didn't think it could be charged independently), and IF were charging it BEFORE trying the lithiums then a faulty charger (eg not cutting out on full charge) COULD have shorted out the unit itself. But obviously you know the sequence you went through.
22.044 (24 Apr 24)
