Pocket GPS World :: View topic - why when i go to ACTIVATE walk does it stay on planning
falconromans
PostPosted: Wed Jul 29, 2009 11:53 pm    Post subject: why when i go to ACTIVATE walk does it stay on planning Reply with quote
why when i go to ACTIVATE walk does it stay on planning, i have it set to tell me distance and time walking etc, but i only noticed 3/4 way around the walk that it said it was on planning. so fun info i like at the end of the walk was not working, what am i doing wrong. I love the Satmap its great compared to my previous gps.[/b]
philpugh
PostPosted: Thu Jul 30, 2009 9:29 am    Post subject: Reply with quote
You may have accidentally moved the joy-stick control. This sends the unit into planning mode. If you notice it has done this then you need to press the LHS button next to the joystick - it should have a dot with concentric circle displayed just above it on the screen. This sends the unit back into GPS mode and places the cursor on your current position.
You can lock the controls to prevent accidental movement of the joystick (I forget how at present - but someone will be along to remind us!) I tend to clip my Active10 to my rucsac and it doesn't appear to suffer from thiss - although you have to be careful putting it into its case to ensure you don't accidentally move the joystick. Satmap should have come up with a more foolproof method (like a prompt to ask you if you are sure you want to enter planning mode - or a separate function activated by one of the other 'soft' buttons - say off the Route menu)
Phil
Bosun
PostPosted: Thu Jul 30, 2009 10:44 am    Post subject: Reply with quote
To lock the buttons to prevent accidental activation,press the On/Off button twice and a padlock icon will appear next to the battery meter.
Ian
philpugh
PostPosted: Fri Jul 31, 2009 2:17 pm    Post subject: Reply with quote
Ian
Told you someone would help - thanks Ian Very Happy
Phil
falconromans
PostPosted: Fri Jul 31, 2009 2:41 pm    Post subject: Thanks all sorted now, GPS/Planning Reply with quote
Thanks all sorted now, went to Ightham Mote, Kent, 7 mile walk, 400ft ascent, used to flat off roads in Essex, so hill climb was hard going but fantastic for us. the Lock and Gps/ planning mode working fine, SATMAP need to sort this flicking from one to the other, its a pain at the moment, maybe I'll get used to it, i just loaded version 1.328 today, the unit is great and even on walking the 1/50k map is ideal. I still carry Explorer active maps, just in case.
FrequentFlyer
PostPosted: Sat Dec 04, 2010 12:20 am    Post subject: Reply with quote
Ian
Is this still possible...I keep trying it with mine while showing the GPS Map page , and nothing ?
LostMike
PostPosted: Sat Dec 04, 2010 9:46 am    Post subject: Reply with quote
FrequentFlyer asked
Ian
Yes it is for me. The on/off button being the large one on the upper right side of the machine. I press it once until it asks if I want to switch off and then press the button again (a lock icon should be showing next to the button at this stage).
LostMike
Satmap A10. Platform 21
Software version 1.5.9193
Satsync 1.525
Bosun
PostPosted: Sat Dec 04, 2010 10:20 am    Post subject: Reply with quote
Yes still works for me also after the upgrade.
Two presses of the On/Off switch as Mike says.
Ian
FrequentFlyer
PostPosted: Sat Dec 04, 2010 10:31 am    Post subject: Whoops! Reply with quote
Apologies...got it now.
22.044 (24 Apr 24)
