Pocket GPS World :: View topic - Quest problems after downloading software update from Garmin
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users
xsive33
PostPosted: Wed May 20, 2009 11:14 pm    Post subject: Quest problems after downloading software update from Garmin Reply with quote
I've had my Quest for the last four years and never had a problem with it. After looking through the Garmin site I noticed a software update for the Quest. I duly downloaded the new software.
Then the problems started;
1. The unit sometimes struggles to find satellites
2. Will switch itself off after it can't find satellites for a while and then back on...sometinmes
3. Will sometimes freeze
4. A new screen of death appeared today ('Loader Loading') and then the unit froze.
I've done the master re-set and still the problems are happening.
It's been such a great little unit so I can only pin-point it to Garmin's new software update.
Any ideas? PLEASE!!!
Kritou
PostPosted: Sat May 23, 2009 11:15 pm    Post subject: Reply with quote
Yep - exactly the same problems. I sent mine in to Garmin with £75 and received a refurbished unit to which I was entitled to the latest mapping (CNE2009) When that was loaded I installed the latest Mapsource version on the PC and system software 4.10 on the Quest - Guess what, same problem!
Back it went to Garmin for a another replacement into which I have loaded all the above - but fully expect the problems to return on this
You cannot fault Garmin's customer service but they don't seem able to determine if it's a system problem on the unit or one elsewhere
Wonder if you can rollback from v4.10 without causing further problems?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users All times are GMT + 1 Hour
22.051 (01 May 24)
