WoREoD Occasional Visitor
Posted: Wed Mar 11, 2009 8:44 pm Post subject: SatNavs & Average Speed |
Given the new average speed camera plans, does anyone know of a SatNav that will display an actual average speed based on GPS?
Ideally it would need to be able to be started as you pass the first set of cameras and then run showing on the display, until reset. |
DennisN Tired Old Man
Posted: Wed Mar 11, 2009 11:49 pm Post subject: |
The closest you'll get is a satnav which activates from a database like PGPSW's and gives audio noises to remind you to look at the displayed speed icon throughout the zone. Maybe also audio warn if you go above the limit. I haven't heard of anything which will calculate your average speed. Presumably you'd want something which could tell you that your average speed is xx, so that you could speed up if you're well below it and slow down if you're over it. But that sounds dodgy - condones breaking the speed limit and might be unworkable over a series of cameras rather than a pair. _________________ Dennis
Two of them are obesiting!! |
M8TJT The Other Tired Old Man
Posted: Thu Mar 12, 2009 9:56 am Post subject: |
Igo based software does pretty much what you want with average speed calculation, but unfortunately the implementation is not good, as the incorrect assumption made by Igo is that SPECS cams always come in pairs. If you are clever enough, you can program a skin to work pretty much how you describe on SPECS. |
kaydee2 Lifetime Member
Joined: Jan 26, 2006 Posts: 38 Location: Hertfordshire, UK
Posted: Sun Apr 12, 2009 12:17 am Post subject: |
My 'old' Garmin Nuvi 660 will display a live average speed.
You press the 'arrival' or 'speed' box (according to whether it is running a route or not) and you get a trip data display with live speed, average overall speed, average moving speed, maximum speed - these can be reset/zeroed at the start of a specs section and run live from then until reset.
Obviously you shouldn't be adjusting or using your sat nav controls while driving but your passenger of course could!!
I don't know if newer Garmin devices do this |
