Pocket GPS World :: View topic - memory map
memory map
kevin2306
PostPosted: Sun Mar 08, 2009 7:18 pm    Post subject: memory map Reply with quote
hi
i bought an acer pda hopeing to run memory map on it to use whilst out in the hills laning. i find that the acer i have will not sync with vista too old i think).
what would be the best / most cost effective way of buying a device that will run memory map and sync with vista?
thanks in advance
kev
PostPosted: Sun Mar 08, 2009 7:53 pm    Post subject: Reply with quote
Contact Memory Map as I am sure they can supply a CAB file installer for the application which only requires Windows Explorer and a card reader to get the application to the device that you own.
Once the application is on the device you can transfer maps to the memory card using the card reader and Windows Explorer/ Memory Map - Mike
aj2052
PostPosted: Mon Mar 09, 2009 12:49 am    Post subject: Reply with quote
You will probably find that your acer was issued with Activsync which is not compatible with Vista you need to update to Windows mobile device center for use with Vista, it is free from Microsoft, even my wm6 unit was supplied with activsync despite being a couple of tears after vista released.
Moto G5s Plus, Sygic 17.4.8
PostPosted: Mon Mar 09, 2009 11:05 am    Post subject: Reply with quote
Freudian slip Very Happy
aj2052
PostPosted: Mon Mar 09, 2009 11:16 am    Post subject: Reply with quote
Freudian slip
Not so sure actually, thinking about it, perhaps even more than a couple or even years.
Despite this Darren i have to agree with your first answer, direct card reading is always my first choice.
nick789uk
PostPosted: Tue Mar 17, 2009 12:43 pm    Post subject: sync with vista Reply with quote
Hi I have an Acer 530 and had to load windows mobile onto my lap top so that it would sync with the pda, you might find it automatically loads when you connect your pda or as a windows update it did with mine hope this helps Nick
aj2052
PostPosted: Wed Mar 18, 2009 2:35 am    Post subject: Reply with quote
I think you need to explain what you need to sync, windows mobile center is not as comprehensive as Activesync was, I mainly use use the sync facility for syncing contacts and files on my PDA.
If you have a cab file this cann usually be installed within the PDA using its internal explorer, i very rarely use a sync application for installing progarms.
Incedently windows mobile will not sync straight off after loading it will after be configured and set up to sync to the files etc to sync initially, and covers contacts,tasks,emails,favorites,files etc.
hope this helps
22.051 (01 May 24)
