Dave Frequent Visitor
Posted: Tue May 18, 2004 10:19 pm Post subject: |
Very interesting! These 2210 lockups I've reported a number of times to TomTom and they haven't found what's causing it, TTN2 was fine but TTN3 is locking up, and interestingly enough I have MicroDrive's in both my 2210's. Hadn't dawned on me to eject the MicroDrive's because everything I have is installed to the SD card, I'll give it a try and let you know how it goes. The lockups I've been getting have been getting worse and worse over time. |
jlw Frequent Visitor
Joined: May 10, 2004 Posts: 402 Location: South Sweden
Posted: Fri May 21, 2004 1:29 am Post subject: |
is any patch out for the 2210 yet? |
alix776 Pocket GPS Moderator
Posted: Fri May 21, 2004 3:11 am Post subject: |
no just use the loastest rom for the 2210 and the software out of the box its qute stable the problems seam to come when the updates are installed
thourgh you will still lose the bt link occasioally when i run mine all i usually get 6 - 7 hrs before it drops the bt link to my tomtom gps _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
njmbtn Occasional Visitor
Posted: Fri May 21, 2004 6:51 pm Post subject: |
I've had a partial fix to the problem I posted a few days ago from TomTom. I was having a problem with 2210, TT3 and a microdrive. They advised me to do two things.
Firstly to upgrade to latest GPS software. This, with a wired GPS, made no difference.
Secondly (and to quote them).....
If the problem continues after the new driver is installed please go into the properties icon in the navigator menu and then the POI Tab. Remove the tick mark from Show Points Of Interest. Tap OK. Then see if this temporarily cures the problem. If this works let us know so we can investigate this issue further.
This does seem to fix it. I drove 150 miles today and worked fine. In final mile I switched back on "show POI" and it froze within 20 seconds!
Hopefully there will be a fix that will allow me to see POI again in Navigator view.... but at least I don't have to remove microdrive each time
Hope that may help you Dave and others |
Posted: Sat May 22, 2004 4:19 pm Post subject: |
njmbtn wrote: | I've had a partial fix to the problem I posted a few days ago from TomTom. I was having a problem with 2210, TT3 and a microdrive. They advised me to do two things.
Nice to hear POI's are realy good to have:) |
ROBBINS Regular Visitor
Joined: Dec 04, 2003 Posts: 82 Location: Worcestershire
Posted: Sun May 23, 2004 9:56 pm Post subject: |
Hi All
This was the first time this weekend that I was able to test in earnest my TT3 upgrade, since I did the upgrade a couple of weeks ago.I travelled about 65 miles in my motorhome to a site that would have been quite diificult to locate with the wife as navigator, but TT3 took us directly to the location with no problems. Over the weekend, I changed the safety speed setting from 60 mph to 40 mph, having read articles on this in other threads.
On the return journey BT GPS connection was lost, and three soft resets did not cure the problem. On the fourth reset, I changed the GPS setting to NMEA 0183V2 9600 on Com 8 from TT wireless GPS BT. This worked, and we carried on our way for about 20 or so miles before another BT connection loss.
I did notice that each time a connection was lost, the screen was in safety speed mode just coming to a change in direction with "Current Location" on the screen. I have therefore changed the safety speed back to 60 mph. Could this be the problem, or is it wishfull thinking.?
I wish I could change back to TT2, but having invested in maps of europe for TT3 this summer, it will not work. I am feeling a little disappointed to say the least and not too confident for continental travel this summer.
Any ideas or suggestions would be welcome.
Alan
IPAQ2210, TT3 Upgrade 3.01(409/2). Rom Upgrade 1.10, BT GPS GR230(holux), Checkpoint v 3.2 |
carl_w Lifetime Member
Posted: Mon Jun 14, 2004 9:47 pm Post subject: |
Happened to me this weekend too. Configuration
IPaq 2210 (ROM v 1.10)
TomTom BT GPS receiver (recently replaced under warranty)
TomTom Navigator v3.01
UK maps on a Crucial CF card (not an SDIO card)
TomTom GPS v3.00
Screen locked up, but it appeared to stop showing directions at the same time (bottom of the readout had the big speed indicator and the compass -- no distance to next turning, ETA, etc.) Other program functions worked OK (could get into the menus and everything).
I've since upgraded to GPS v3.02 so we'll see if that fixes it. |
Posted: Mon Jun 14, 2004 10:34 pm Post subject: |
I have ipaq 2210 rom 1.0.. (dont dare to update ) Uses tomtom3 with the latest driver... never had a problem! _________________ Ipaq 2210 (rom 1.10)
Fortuna Clip-On
CF: Kingston Elite Pro 512 MB
CF: Lexar 256 MB
Poporta Alu-Case |
Colin58 Occasional Visitor
Posted: Sun Aug 01, 2004 8:51 pm Post subject: |
I also have ad no lockups and hve used the systemfor several long journeys. I am also on ROM 1.10. I had no option but to install version 3.01 as that is the version supplied on CD. I have nopt performed any updates. |
Rmac Occasional Visitor
Posted: Mon Aug 23, 2004 5:15 pm Post subject: Tom Tom V 3.03 |
I see that TT3 is now at version 3.03 which TT say will cure this problem - any feedback on this 2210 problem |
lbendlin Pocket GPS Staff
Posted: Mon Aug 23, 2004 5:49 pm Post subject: |
Some say it helped some say it doesn't - if in doubt stick with 2.07 _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
voice_of_reason Regular Visitor
Posted: Tue Aug 24, 2004 10:45 am Post subject: |
Hi there,
I'm new to the forum. Just got my iPAQ 2210, waiting for tomtom BT receiver to be delivered (and feeling very worried reading this thread!)
I haven't really been able to find an answer to this, but apologies if it's been covered elsewhere - can anyone tell me exactly how common this Navigator 3/iPAQ 2210 probem is? I've noticed a few posts from people who say they have this combination and haven't experienced any problems at all. So is it really just a few reported cases (as tomtom seem to suggest on their website!) or are we talking about a 50/50 chance as to whether it will work or not?
I just want to know if I'm definitely going to experience this probem, or whether there's any chance that I'll be OK!! I know the best thing is to wait and see, but I'm seriously wondering if I should re-think my purchase.
Cheers. |
Posted: Tue Aug 24, 2004 1:32 pm Post subject: |
It's a 50/50 problem, but with an easy fix, so there is no reason to rethink your purchase. _________________ Lutz
Posted: Tue Aug 24, 2004 2:37 pm Post subject: |
Thanks for the reply. Is it definitely an easy fix? Because from what I've read from the replies in this thread and others, applying the updates to Navigator hasn't helped a lot of people.
Or do you mean some other kind of fix?
Cheers! |
Posted: Tue Aug 24, 2004 2:52 pm Post subject: |
Applying 3.03 has not always helped. But if you are going back to 2.07 then it will work. It's just that some folks are reluctant to downgrade ;-) _________________ Lutz
